2015 Nissan Rogue, Retained Radio Accessory Wire
jsigna
Copper - Posts: 157
Posted: January 28, 2023 at 5:54 PM / IP Logged Link to Post Post Reply Quote jsigna
Hey guys,
I can't for the life of me find an retained acc wire to use with an aftermarket head unit. I wound up using a normal acc wire but my uncle really wants the radio to stay on until the door is opeb.
Anyone have any ideas?
Thanks,
Justin
Platinum - Posts: 13,674
Posted: January 28, 2023 at 9:22 PM / IP Logged Link to Post Post Reply Quote i am an idiot
https://www.the12volt.com/relays/relaydiagram30.html
jsigna
Copper - Posts: 157
Posted: January 28, 2023 at 10:18 PM / IP Logged Link to Post Post Reply Quote jsigna
The vehicle has retained accessory already. I'm just looking for something to tap into.
geepherder
Platinum - Posts: 3,668
Posted: January 29, 2023 at 7:41 AM / IP Logged Link to Post Post Reply Quote geepherder
Just a general tip (not vehicle specific), but check the power window circuit. If there's an accessible power window relay, you may be able to find a source there.
Posted: January 29, 2023 at 10:51 AM / IP Logged Link to Post Post Reply Quote i am an idiot
The cigarette lighter / power port near the radio should also be retained accessory.
jsigna
Copper - Posts: 157
Posted: January 30, 2023 at 12:16 PM / IP Logged Link to Post Post Reply Quote jsigna
There is apparently a relay under the radio for the power windows with a blue wire that is RAP. Cig lighter is 12v constant. Going to look for this relay this weekend. Wish me luck!
tonanzith
Gold - Posts: 601
Posted: February 02, 2023 at 11:41 PM / IP Logged Link to Post Post Reply Quote tonanzith
If the stock radio was retained acc then it’s this wire.
Radio Ignition
Wire Color     Lt. Green or White
Polarity     +
Wire Location     Radio, white 20 pin plug, pin 7
Gary Sather
jsigna
Copper - Posts: 157
Posted: February 03, 2023 at 2:18 PM / IP Logged Link to Post Post Reply Quote jsigna
I'll check this tomorrow. I used a metra wire harness. Everything else worked fine but this. I'll check that wire though tomorrow.
I can't wait to see if this power windows relay is really under the radio if that doesn't work out.
Thanks,
Justin Signa
Wednesday, May 29, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
