2002 Envoy Alarm info
Welcome Guest :)
underground
Copper -
Posted: September 29, 2002 at 10:17 PM / IP Logged
Looking for 2002 Envoy alarm info as well as stereo info!
djfearny2
Silver -
Posted: September 29, 2002 at 10:41 PM / IP Logged
here is the alarm info:::
| Vehicle Color | Location |
Start: | | Yellow | YELLOW | IGNITION SWITCH HARNESS * |
Ignition #1: | | Blue | PINK | IGNITION SWITCH HARNESS |
Ignition #2: | | Green | WHITE | IGNITION SWITCH HARNESS |
Ignition #3: | | Wht/Blk | N/A | |
Accessory: | | White | ORANGE | IGNITION SWITCH HARNESS |
Brake Light: | | Orange | WHITE | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | Green | WHITE | IN BLUE PLUG AT THE ECM ON DRIVER'S SIDE OF MOTOR |
Parking Lights: | | Yellow | BROWN (+) | DRIVER'S KICK PANEL |
Headlights: | | Yellow | | |
OEM Alarm Disarm: | | Brn/Wht | LT. GREEN (-) | INSIDE OF DRIVER'S DOOR AT MODULE ** |
OEM Alarm Arm: | | n/a | | |
Diesel Glow Plug: | | RED / Black | N/A | |
Clutch Bypass Wire: | | n/a | N/A | |
Notes: | | * This Vehicle Is Equipped With GM's PASSLOCK II Anti-Theft System; See Installation Note #113 - Bypassing GM's Passlock II Security System. |
Alarm and Keyless Entry Wiring Colors and Notes |
Function | | DTI Color | Vehicle Color | Location |
Constant +12 Volts: | | Red | RED | IGNITION SWITCH HARNESS |
Starter Kill: | | Vlt or Wht | YELLOW | IGNITION SWITCH HARNESS * |
Ignition +12 Volts: | | Orange | PINK | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | Brown | GRAY/BLACK (+) | UNDERNEATH DASH AT COURTESY LAMP |
OEM Horn: | | Blue | BLACK / YELLOW (-) | STEERING COLUMN HARNESS |
Power Lock: | | Wht/Red | SEE NOTE BELOW *** | |
Power Unlock: | | Yel/Red | SEE NOTE BELOW *** | |
Trunk Release: | | Grn/Wht | N/A | |
Alarm Input Wire: | | R/W or Gy/Bk | GRAY/BLACK (+) | UNDERNEATH DASH AT COURTESY LAMP |
Notes: | | ** Module Is Part Of Power Windows/Locks Switch Assembly In Driver's Door. *** Must Go Inside Of Driver's, Front Passenger And Rear Hatch To Wire Three Separate 5-Wire Reverse Polarity Systems To The Lock Motors In Each Door. The Wires Are GRAY For Lock And TAN For Unlock. This Will Unlock/Lock The Two Front Doors And The Rear Hatch. The Middle Doors, Must Be Wired As A Negative Trigger System Using LT. BLUE For Lock And WHITE For Unlock. The Wires Are Located Under The Rear Seat On The Driver's Side. See Installation Notes #201 - Negative Pulse Door Locks And Installation Note #203 - Reverse Polarity Door Lock System. icant find the speaker chart for that car. i iwll look but continue the post maybe someone else has it. |
Jon
Installer/Help Technician
---coral springs florida---
Sunday, June 9, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
