2005 Toyota Matrix Alarm/Remote Start Wiring
Welcome Guest :)
euroman
Member -
Posted: December 29, 2004 at 3:22 AM / IP Logged
Purchased an alarm and remote start But I need wiring info for a 2005 Toyota Matrix
KarTuneMan
Platinum -
Posted: December 29, 2004 at 6:44 PM / IP Logged
12volts | white (25A), black (15A) | + | ignition harness |
Starter | red | + | ignition harness |
Second Starter | N/A | | |
Ignition | BLACK/ white | + | ignition harness |
Second Ignition | BLACK / YELLOW | + | ignition harness |
Third Ignition | N/A | | |
Accessory | blue/red | + | ignition harness |
Second Accessory | N/A | | |
Keysense | blue/black | - | ignition harness |
Notes: Using the status output to trigger this wire during remote start will disarm the factory alarm without unlocking the doors. |
Power Lock | green | - | driver kick, 10 pin plug |
Notes: Meter these wires while turning the key in the driver door key cylinder. |
Power Unlock | blue / YELLOW (double pulse) | - | driver kick, 10 pin plug |
Notes: Meter these wires while turning the key in the driver door key cylinder.Can also use the passenger door key cylinder wire for unlock, which only requires a single pulse. It is blue/black (-) in the passenger kick in a 10 pin plug. |
Lock Motor | blue | 5wi | driver kick, blue 12 pin plug |
Unlock Motor | red | 5wi | driver kick, blue 12 pin plug |
Parking Lights+ | green | + | driver kick, harness to rear |
Parking Lights- | GREEN / WHITE | - | headlight switch |
Hazards | yellow/black | - | flasher relay left of fuse box |
Turn Signal(L) | GREEN/ black | + | flasher relay left of fuse box |
Turn Signal(R) | GREEN/ YELLOW | + | flasher relay left of fuse box |
Reverse Light | RED / black | + | front of fuse box, 10 pin plug |
Door Trigger | RED / white | - | interior light switch on dash |
Dome Supervision | RED / black | - | interior light switch on dash |
Trunk/Hatch Pin | common with door trigger wire | | |
Hood Pin | N/A | | |
Trunk/Hatch Release | blue/white | - | release switch on dash |
Power Sliding Door | N/A | | |
Factory Alarm Arm | arms with lock | | |
Factory Alarm Disarm | disarms with unlock | | |
Disarm No Unlock | use key sense wire | | |
Tachometer | black | ac | ECM, far right plug, pin 5 |
Notes: The ECM (Engine Control Module) is behind the glove box.On the XRS models, the tach wire is in the second plug from the right, pin 3. |
Wait to start | N/A | | |
Brake Wire | GREEN / WHITE | + | brake pedal switch |
Parking Brake | RED / black | - | parking brake switch |
Horn Trigger | GREEN/ YELLOW | - | steering column |
Memory Seat 1 | N/A | | |
Memory Seat 2 | N/A | | |
Memory Seat 3 | N/A | | |
Immobilizer Bypass Module: | Required: Yes | Type: Transponder | Part #: 556U or 555U |
Tuesday, June 4, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
