2004 Ford Explorer remote start
ziggyb222
Silver - Posts: 593
Posted: December 17, 2004 at 6:18 PM / IP Logged
Will a new 2004 ford explorer even try to start with out a bypass module..or will it crank then run and then shut off... I am installing a remote start and it will come on when I push the start button, but doesnt crank.... Was wondering if the bypass module was holding it back or maybe some sort of factory security thing... Any ideas???
prdjr165
Copper - Posts: 293
Posted: December 17, 2004 at 7:23 PM / IP Logged
It should crank but not start,Check your hoodpin switch,and you might have to program the tach setting on the remote starter first.
dustimizer
Member - Posts: 11
Posted: December 17, 2004 at 8:47 PM / IP Logged
The truck will not crank if the security system does not recieve the proper code from the key or bypass module.  Just did one yesterday.
ziggyb222
Silver - Posts: 593
Posted: December 18, 2004 at 5:47 AM / IP Logged
dustimizer....you were right.. truck would not crank with out bypass module installed.. all set now....thanks for your help....
jonkolo
Member - Posts: 13
Posted: December 26, 2004 at 9:26 PM / IP Logged
Where did you connect the tach wire?  Is your Explorer a V-8 or V-6?  Any problems with the remote start?
Here is my problem:  https://www.the12volt.com/installbay/forum_posts.asp?tid=45797&PN=1&tpn=1
