door actuator relays
davidwp13
Member - Posts: 28
Posted: April 18, 2004 at 7:05 PM / IP Logged
 Hi I am new at this BUT I need help wiring the door lock act. from a Python 660XP it has a blue and a green wire ,I have the 524F Direct act.
PLEASE HELP
David
chriswallace187
Gold - Posts: 1,661
Posted: April 18, 2004 at 11:22 PM / IP Logged
You can use two SPDT relays or DEI's 451M. Wire it like this: Actuators/Reverse Polarity Diagram
The blue wire is your (-) unlock output and the green wire is your (-) lock output.
Also, if you use a 451M, it should plug into the alarm brain in place of the 3-pin plug with the lock and unlock wires; in that case just ignore the 85s and 86s in the above diagram.
cb1oss
Member - Posts: 13
Posted: May 24, 2004 at 9:44 AM / IP Logged
Sorry for my ignorance, but where would the "actuator" wires go? I have no idea what that is. I assume thoes wires are the brown and white ones.
chriswallace187
Gold - Posts: 1,661
Posted: May 24, 2004 at 7:29 PM / IP Logged
The actuator wires from a 451M are GREEN/ black and blue/black, and they go to the green and blue wires, respectively, on your aftermarket actuator(s). The BROWN / black and WHITE/ black wires are terminals 87a, and go to ground.
