2003 Dodge Ram 1500 Alarm/Remote Start/Stereo Wiring
Sound Pressure
Silver - Posts: 711
Posted: September 25, 2002 at 10:34 PM / IP Logged
In need of a wiring chart on a 2003 dodge ram 1500. Will be installing one of two alarms, either a viper not sure what model or an auto command model #29646 keyless entry & starter kill alarm. Is the autocommand any good? Does it have everything needed to install into this truck? I have no info on it. If the viper is chosen most likely it will be the 550esp(remote start) Anything to look out for? Immobillizer,factory alarm. Never installed the immobillizer, is it hard to install?
Thanks,
Sound Pressure
Platinum - Posts: 12,488
Posted: September 26, 2002 at 12:25 AM / IP Logged
I believe the wiring has not changed since the 2002 model year for the Dodge trucks. Autocommand is made by DesignTech Corp. The model number you have is not one that i can find anything for either. Is there any other model or serial numbers you have on this unit ?
Sound Pressure
Silver - Posts: 711
Posted: September 26, 2002 at 12:45 AM / IP Logged
I'm not sure what model number it is or if it has features as the viper with factory re, and dis arm feature etc.
2-5 button remotes with 600 ft. range,5-zone security: shock sensor,ignition,doors,valet,optional add-on, adjustable dual-stage ceramic crystal shock sensor, anti-scan technology, multi tone 111db siren, starter kill, active/passive arming, remote keyless entry and trunk open, driver side priority, remote panic, anti-car jacking, car finder, one remote can control up to 4 vehicles with first defense.
Ever heard of the fusion 4500 series alarm with built in trasponder immobiliser? Any good?
I'll check on the first page in the database for the 2002.
Sound Pressure
Sound Pressure
Silver - Posts: 711
Posted: September 26, 2002 at 12:48 AM / IP Logged
No records for the 2002 models in the vehicle wiring information. Would you have this?
Sound Pressure
Posted: September 26, 2002 at 1:02 AM / IP Logged
|              12V|pnk/blk & RED / wht   |+  |ignition harness            |
|          STARTER|yellow              |+  |ignition harness            |
|         IGNITION|blue     (16 awg)   |+  |ignition harness            |
|  SECOND IGNITION|red or RED / wht      |+  |ignition harness            |
|        ACCESSORY|green & orange      |+  |ignition harness            |
| SECOND ACCESSORY|blue & blk/wht *7   |+  |ignition harness            |
|       POWER LOCK|WHITE/ green *1      |-  |driver kick panel           |
|     POWER UNLOCK|same wire           |   |                            |
|       LOCK MOTOR|tan/pnk or tan/blk  |   |driver kick panel           |
|     UNLOCK MOTOR|blue                |   |driver kick panel           |
|    DISARM DEFEAT|tan/white           |   |passenger kick panel        |
| PARKING LIGHTS +|BLACK / YELLOW        |   |relay under hood at pwr ctr |
| PARKING LIGHTS -|purple / YELLOW *2    |   |headlight switch            |
|       HEADLIGHTS|purple / YELLOW *2    |-  |headlight switch            |
|     DOOR TRIGGER|*3                  |-  |*3                          |
| DOME SUPERVISION|use door trigger    |   |                            |
|  FCTRY ALARM ARM|lt GREEN/ orange *4  |-  |driver kick panel           |
|FCTRY ALRM DISARM|same wire           |   |                            |
| DISARM NO UNLOCK|same wire           |   |                            |
|       TACHOMETER|NOT GREEN/ orange    |   |ign coil, coil pac, injector|
|      SPEED SENSE|WHITE/ orange        |   |conn. 2, pin 27 @ PCM *5    |
|       BRAKE WIRE|WHITE/ tan           |+  |brake pedal switch          |
|     HORN TRIGGER|BLACK/ red           |-  |steering column             |
|           WIPERS|brn/wht(L),rd/yel(H)|+  |wiper motor                 |
|  LF WINDOW UP/DN|lt blue - white     |A  |driver window switch        |
|  RF WINDOW UP/DN|brn/wht - pur/wht   |A  |driver kick panel           |
|  LR WINDOW UP/DN|RED / blk - blu/wht   |A  |driver kick panel           |
|  RR WINDOW UP/DN|grn/wht - gry/blk   |A  |driver kick panel           |
|        RADIO 12V|pink                |+  |radio                       |
|     RADIO GROUND|BLACK/ green         |-  |radio                       |
|     RADIO SWITCH|BROWN / red           |+  |radio                       |
| RADIO ILLUMINATE|ORANGE / blue (dimmer)|+  |radio                       |
|       LF SPEAKER|lt grn/rd-lt grn/grn|   |radio or amplifier *6       |
|       RF SPEAKER|lt blu/pu-lt blu/blk|   |radio or amplifier *6       |
|       LR SPEAKER|wht/red - wht/blk   |   |radio or amplifier *6       |
|       RR SPEAKER|tan/pur - tan/blk   |   |radio or amplifier *6       |
Notes:
NOTE: For the 2002 Ram 2500/3500, refer to the 2001 techsoft sheet.    NOTE:  Chrysler vehicles that use a gray ignition key have an immobilizer system that needs to be bypassed when remote starting. Use DEI part number 555C or 555U.  *1 Lock requires a negative trigger thru a 820 ohm resistor. Unlock requires a negative trigger thru a 330 ohm resistor. MUST use relays.  *2 Parking lights require a negative trigger thru a 330 or 1.4K ohm resistor. Headlights require a negative trigger thru a 1.8K ohm resistor. There is a rest resistance on the wire, so MUST use a relay to isolate away from the switch.  *3 The LF door trigger is tan, and the LR door is tan/orange. These wires are in the driver kick panel. The RF door trigger is tan/red, and the RR door is tan / YELLOW. These wires are in the passenger kick panel. Use all wires and diode isolate each. See directfax document #1076 for wiring information.  *4 This will also do door locks. Arm/lock is negative trigger thru a 2K ohm resistor. Disarm/unlock is negative trigger thru a 480 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays.  *5 The PCM (Powertrain Control Module) is on the passenger side firewall.  *6 The amplifier is located behind the glove box.  *7 These wires may not be necessary for remote start.
Posted: September 26, 2002 at 1:07 AM / IP Logged
The Fusion idea of built in transponder Immobilizer doesn't seems very feasible to me. The reason being is that there are too many different brands of immobilizers from different car manufacturer's. They would have to have about a half dozen different Fusions systems to accommodate the different systems. Do they have more than one model of this alarm or just that one ?
Sound Pressure
Silver - Posts: 711
Posted: September 26, 2002 at 1:27 AM / IP Logged
Thanks for the wiring info Jeff!
Would the single wire dodge caravan hookup that is posted in the car security information work for this truck using the resistors needed above? The parking lights can I just run that resistor inline with the switchable lead neg/pos parking light wire form the alarm?
These wires that are for the trigger work as the door locks as well or am I reading that wrong?
DiArm/lock is negative trigger thru a 2K ohm resistor. Disarm/unlock is negative trigger thru a 480 ohm resistor. Single pulse will do disarm without unlocking the doors. Unlock requires a double pulse. MUST use relays.
^I would not have to do the above if I am dis-arming the alarm with the viper ro the other alarm right? Kinda lost sorry. I have not had the chance to tackle this type truck with an alarm.  Good thing that it is only keyless entry with the alarm. No remote start yet, but possible.
As far as the fusion that was the only model that I've seen with that built into it. It is true what you said about the different immobilisers out there.
Sound Pressure
Posted: September 26, 2002 at 9:09 AM / IP Logged
  • Yes the diagram is the same.... but change the resitor values.
  • The *4 is for the alarm disarm... not part of the * 3 portion of the details
  • The disarming of the OEM alarm system is only necessary if you are adding a remote starter to the vehicle. Otherwise this connection is not necessary.
  • NOTE* Both the Accessory wires have to be connected  so you do not receive an error on your dash. GREEN and ORANGE wires must be powered ( use relay in the same fashion as the 2 ignition )
Sound Pressure
Silver - Posts: 711
Posted: September 26, 2002 at 10:12 PM / IP Logged
Thanks Jeff,
Your a great help! Appreciate all the info.
Sound Pressure
Posted: September 27, 2002 at 12:40 AM / IP Logged
No problemo
