07 pontiac g6 sedan alarm/remote starter
swissmademan
Member - Posts: 9
Posted: December 28, 2007 at 10:43 PM / IP Logged
Can anybody please post the wiring diagram for an 07 G6? I'm trying to do an alarm and can only find 05 and 06 diagrams. As always, thanks for the help!
SwissMadeMan
KarTuneMan
Platinum - Posts: 7,056
Posted: December 28, 2007 at 11:51 PM / IP Logged
 PASSIVE ANTI-THEFT YES TRANSPONDER   SEE NOTES
 12 VOLTS RED / white (see notes) Ignition switch harness   +
 IGNITION Pink Ignition switch harness   +
 ACCESSORY Brown Ignition switch harness   +
 STARTER SEE NOTES
 No connection required for remote start. The vehicle will crank when accessory powers down during start cycle.
 TACH SIGNAL White Ignition module on engine   AC
 This is for the 4 cylinder engine. On the 6 cylinder engine use VIOLET in the same location.
 FUEL INJECTOR Opposite from Pink At any injector on engine   AC
 LOCK White In C1 connector on BCM   -
 One wire system locks with ground (-) and unlocks with a 1.5K resistor to ground (-). The BCM is located with the fusebox on the passenger side of the center console. Connectors run from left to right C1 (72-pin), C2 (72-pin), C3 (40-pin), C4 (not used).
 UNLOCK White In C1 connector on BCM   -
 DOORPIN SEE NOTES
 Gray/black (dr. door), Tan/white (pass door), Lt.blue/black (left rear door) & Lt.GREEN/ black (right rear door). All 4 wires are found at the BCM on the right side of the center console in the large gray plug on the end of the module.
 HOODPIN Pink/black In C1 connector on BCM   -
 TRUNK PIN ORANGE / black In C1 connector on BCM   -
 TRUNK RELEASE BROWN / white In C1 connector on BCM   -
 FACTORY ARM With OEM remote only
 FACTORY DISARM Lt.Green In C1 connector on BCM   -
 BRAKESWITCH White Brake switch or C1 plug on BCM   +
 PARKLIGHTS Brown In C3 connector on BCM   +
 HAND BRAKE Lt.blue In C1 connector on BCM   -
 HORN Tan In C2 connector on BCM   -
VSS WIRE Brown driver kick panel (at power interface module)   AC
 TRANSPONDER 12 VOLTS RED / white In black plug on ignition switch   +
 TRANSPONDER DATA Green In black plug on ignition switch   DATA
 PASSLOCK DATA White In 6-pin green plug at ignition switch   DATA
 PASSLOCK GROUND WHITE/ black In 6-pin green plug at ignition switch   -
swissmademan
Member - Posts: 9
Posted: December 31, 2007 at 7:54 AM / IP Logged
Thanks a lot man! This is a big help.
SwissMadeMan
jqadamziz
Posted: January 02, 2008 at 11:10 PM / IP Logged
hey there, how did this info work out for ya.  ive been trying to get a r/s working in an 07 g6 all afternoon and getting nowhere.
techman93
Silver - Posts: 591
Posted: January 02, 2008 at 11:19 PM / IP Logged
Pontiac G6's stink to work on. I had to to take apart both sides of dash just to do an Ipod interface.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
