07 aveo, viper 160xv
bullpar
Member - Posts: 36
Posted: January 04, 2008 at 10:08 AM / IP Logged
Hello all, I have an 07 Aveo5 hatchback Automatic. My keys have the lock and unlock buttons so I assume it has the passlock 2 system, Is that true? I have the wiring diagrams for an 04 aveo hatchback. Are these prints the same as an 07? Also does anybody have prints on the passlock system. I am installing a viper 160xv with the 556L interface unit.  Thank you
Twelvoltz
Platinum - Posts: 2,384
Posted: January 04, 2008 at 12:23 PM / IP Logged
Audiovox lists:
          #510284: 2007 CHEVROLET AVEO 4DR HATCHBACK WITH 1.6L ENGINE AND STANDARD AUDIO SYSTEM
     Audio/Mobile Video
     WIRE          COLOR          POLARITY          LOCATION
     Battery          ORANGE          (+)          RADIO HARNESS
     Accesory          YELLOW          (+)          RADIO HARNESS
     Ground          BLACK          (-)          RADIO HARNESS
     Illumination          BROWN / WHITE          (+)          RADIO HARNESS
     Dimmer          LIGHT GREEN/ RED          (-)          RADIO HARNESS
     LF Speaker (+)          VIOLET
               THESE WIRES ALSO GO TO THE FRONT LEFT TWEETER
     LF Speaker (-)          LIGHT GREEN
     RF Speaker (+)          LIGHT BLUE
               THESE WIRES ALSO GO TO THE FRONT RIGHT TWEETER
     RF Speaker (-)          BROWN
     LR Speaker (+)          DARK GREEN
     LR Speaker (-)          GRAY
     RR Speaker (+)          DARK BLUE
     RR Speaker (-)          WHITE
     Steering Cntrls          NO
     Speed Cntrl          NO
     Radio Security          YES
     Security
     Battery          RED / BLACK          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
     Starter 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          WHITE          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Domelight Super          WHITE          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Trunk Trigger          ORANGE / BLACK          (-)          IN HARNESS AT COURTESY LIGHT IN TRUNK
     Hood Trigger          BROWN / BLACK          (+)          IN HARNESS AT PIN SWITCH UNDER HOOD
     Alarm Disarm          DARK BLUE          (-)          IN HARNESS IN DRIVERS KICKPANEL
     Parking Lights          BROWN          (-)          IN HARNESS AT VEHICLE LIGHT SWITCH
     Convenience
     Headlights-Lo          BLACK/ WHITE          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Wipers-Lo          DARK BLUE          (+)          AT VEHICLE WIPER CONTROL SWITCH
     Wipers-Hi          WHITE          (+)          AT VEHICLE WIPER CONTROL SWITCH
     Parking Brake          BROWN          (-)          AT SWITCH AT VEHICLE PARKING BRAKE
     Remote Start
     Accessory 1          RED / BLACK          (+)          IGNITION SWITCH HARNESS
     Accessory 2          YELLOW          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          LIGHT GREEN          (+)          IGNITION SWITCH HARNESS
     Tachometer          GRAY          (AC)          AT ECM MODULE BEHIND DRIVERS SIDE HEADLIGHT UNDER HOOD
               PIN #25
     Speed Sense          DARK GREEN / WHITE          (AC)          AT ECM MODULE BEHIND DRIVERS SIDE HEADLIGHT UNDER HOOD
               MAY ALSO BE DARK GREEN
     Brake Lights          BROWN          (+)          AT SWITCH ABOVE BRAKE PEDAL
               WIRE MAY ALSO BE ORANGE IN SOME VEHICLES.
     Reverse Lights          LIGHT GREEN          (+)          IN HARNESS IN DRIVERS KICKPANEL
     Horn          BLACK/ WHITE          (-)          IGNITION SWITCH HARNESS
     Modules
     WIRE          LOCATION
     Please select another category
     Doorlocks/Windows
     Power Unlock          LIGHT GREEN          (-)          AT DOORLOCK RELAY MODULE IN PASSENGER KICKPANEL
     PowerLock          GRAY          (-)          AT DOORLOCK RELAY MODULE IN PASSENGER KICKPANEL
     Driver Mtr Unlock          DARK BLUE          (REV)          AT MOTOR IN DOOR
     Driver Mtr Lock          WHITE          (REV)          AT MOTOR IN DOOR
     Pas Mtr Unlock          DARK BLUE          (REV)          AT MOTOR IN DOOR
     Pas Mtr Lock          WHITE          (REV)          AT MOTOR IN DOOR
     LF Window Up          WHITE          (REV)          AT DRIVER WINDOW CONTROL SWITCH IN DOOR
     LF Window Dn          DARK BLUE          (REV)          AT DRIVER WINDOW CONTROL SWITCH IN DOOR
     RF Window Up          BROWN          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RF Window Dn          DARK GREEN          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     LR Window Up          GRAY/DARK GREEN          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     LR Window Dn          DARK GREEN/ RED          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Up          VIOLET          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     RR Window Dn          LIGHT BLUE          (REV)          IN HARNESS IN DRIVER KICKPANEL TO DOOR
     Sunroof Open          DARK BLUE          (REV)          AT SUNROOF MOTOR
     Sunroof Close          BROWN          (REV)          AT SUNROOF MOTOR
     Note: Audiovox makes no representation or warranty with respect to the above information including its accuracy, completeness, or its freedom from third parties' proprietary rights. Audiovox disclaims all liability or responsibility for errors or omissions therein or any decision made by the recipient in reliance thereon. The installer must verify any circuitry with the proper test equipment prior to installation.
The Aveo does not use the Passlock II system, some do use a transponder system but it is an option only on the LT models I believe. Either way the 556L will not work. You would need a key-in-a-box bypass or a data based bypass.
bullpar
Member - Posts: 36
Posted: January 04, 2008 at 6:26 PM / IP Logged
Thank you very much for the diagram, so What do I need for the keys. How can I tell If I have the transponder? On the back of the car it says aveo5.
bullpar
Member - Posts: 36
Posted: January 13, 2008 at 7:37 PM / IP Logged
I'm in process of installing a Viper 160xv. 3 questions
1. How do I test for the tach wire? I looked at pin 25 for a grey wire at the ecm, and its not grey, I also looked at the tach connector for a white wire and theres 3 or 4, which one is it?
2. How about the door unlock? I tied into the relay on the passenger side kickpanel onto the light green wire and grey wire is this correct?
3. How do I disarm the factory alarm? I tied into the driver kickpanel blue wire.
Twelvoltz
Posted: January 13, 2008 at 8:47 PM / IP Logged
You should always test your wires for the proper function prior to hooking into them.
1. To test for the proper tach reference wire, set your meter to AC voltage, hook your black lead to ground and your red lead to the wire in question. When your engine RPM increases so will the voltage reading on the meter if you are on the right wire.
2. To test for door negative locks, put your meter on DC voltage. Hook your red lead to constant +12V and hook your black lead to the wire you suspect as being your lock wire. Press lock on the door if you are on the correct wire the meter will read +12V.
3. To test for the proper negative factory alarm disarm wire, again hook your DMM red lead to +12V, and probe the wire in question with the black lead. When you turn the key in the door cylinder to the unlock position the meter should read +12V.
tedmond
Gold - Posts: 4,610
Posted: January 13, 2008 at 9:41 PM / IP Logged
1) test with a DMM (digital volt meter) set it to AC since you are reading the peaks. place black to neg and red to that wire. It will read from 1 - 6 volts and will change when RPM changes. testing will give you the proper one.
2) the wires are correct, but always test your wires befor connecting anything to it. they are type B or a negative trigger to activate factory relays.
3) DARK BLUE in drivers kick panel. Send a (-) pulse to this wire will disarm FACTORY alarm.
bullpar
Member - Posts: 36
Posted: January 14, 2008 at 7:45 AM / IP Logged
Are the wireing diagrams available for the 07 aveo hatchback? I looked around with no luck.
bullpar
Member - Posts: 36
Posted: January 15, 2008 at 8:30 PM / IP Logged
I tested the white wire at the tach connector and with the engine running I got 1vac. it changed but not to 6vac. The other couple of white wires didnt do anything.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 19, 2008 at 9:31 PM / IP Logged
12 VOLTS Orange & RED / black Ignition switch harness   +
 IGNITION Pink Ignition switch harness   +
 ACCESSORY RED / black Ignition switch harness   +
 ACCESSORY 2 Yellow (Large) Ignition switch harness   +
 STARTER Yellow (Small) Ignition switch harness   +
 KEY SENSE Lt.green Ignition switch harness   -
 TACH SIGNAL White At coil on driver's side of engine   AC
 LOCK Gray/Green At doorlock module   -
 Doorlock module is located under center console just in front of handbrake.
 UNLOCK YELLOW /GREEN At doorlock module   -
 DOORPIN White In driver's kickpanel   -
 TRUNK PIN ORANGE / black At light in rear compartment   -
 FACTORY DISARM Blue In driver's kick panel   -
 BRAKESWITCH Brown At switch above brake pedal   +
 PARKLIGHTS Brown At light switch harness   -
 HAND BRAKE Brown At switch on handbrake lever   -
 HORN Black or BLACK/ white At steering column   -
 IF horn wire is Black you may need to add a relay as this wire goes directly to the high current ground input of the horn itself.
 VSS WIRE GREEN / WHITE At PCM under hood   AC
 TRANSPONDER IGNITION Pink 7 pin conn. At the transponder receiver   +
 TRANSPONDER DATA 1 BLACK/ white 7 pin conn. At the transponder receiver   DATA
 TRANSPONDER GROUND black 7 pin conn. At the transponder receiver   -
 DATABUS INTERFACE Pin-2(top row from left) Diagnostic plug below dash   DATA
