how to calculate time alignment?
arpangestu
Posted: January 04, 2008 at 11:04 AM / IP Logged
guys i need some help, how to calculate time alignment? for alpine pxa 701 & TA for clarion, i trouble to find the fix calculation for TA, every time i ask to some one they give me diffirent answer, by the way i am from indonesia, thanks Bro
collyn eastham
Member - Posts: 27
Posted: January 04, 2008 at 11:25 AM / IP Logged
Since the arrival of sound from the speakers to your ears is influenced by many first and second order reflections in a car, setting time alignment by ear is the best way to get a solid center image. Of course, proper speaker locations and phasing of speakers is the trues best way, since adjusting arrival times only fixes one spot in the car and wreaks havoc on every other location in the car.
Collyn Eastham
a.k.a. 300MBQuart
08 HHR Panel
DYohn
Platinum - Posts: 10,741
Posted: January 04, 2008 at 11:27 AM / IP Logged
Well you could use the microphone and allow the PXA-701 to set itself up automatically.  If you need to do it manually, simply use a tape measure and measure the linear distance from the center of each loudspeaker to the primary listening position (the driver's head) or, if you're looking for a more general alignment, use a location at about ear level between the two front seats.  Then see page 8 of your PXA-701 owner's manual and follow the instructions.
kfr01
Gold - Posts: 2,121
Posted: January 05, 2008 at 9:59 AM / IP Logged
This might not be germane to your specific headunit, but I posted the general formula for calculating milliseconds of delay based on distance in the following thread:
Remember to Search the12volt.com For Answers to Questions
New Project: 2003 Pathfinder
arpangestu
Posted: January 05, 2008 at 2:49 PM / IP Logged
thanks guy for your replies, and for kfr01, yeah i read that on manual book alpine, but if you use that calculate and listen with five piano track its still cannot be perfect
how to calculate time alignment? - Last Post -- posted image. javascript:AddSmileyIcon('how to calculate time alignment? - Last Post -- posted image.')
