02 sunfire pljx and check engine light
schlever
Member - Posts: 9
Posted: January 21, 2008 at 11:49 AM / IP Logged
Installed a remote starter in my 02- sunfire with a PLJX module. It works fine now, but the passlock II light and check engine light remain on at all times as long as the PLJX is installed. Is it possible the GWR from my ultrastart isn't sending enough current to the PLJX or that the PLJX is defective?
moonliter
Copper - Posts: 322
Posted: January 21, 2008 at 4:03 PM / IP Logged
If you unplug the PLJX, would the passlock 2 light goes away ?
schlever
Member - Posts: 9
Posted: January 21, 2008 at 4:30 PM / IP Logged
Yes whenever I unplug the unit, the passlock II light goes away.
Does anyone know if the sunfire has a keysense wire?
extreme1
Silver - Posts: 1,070
Posted: January 21, 2008 at 4:41 PM / IP Logged
got the jumper on the PLJX in the right position?
it should jump the two pins away from the connector, check that and reprogram.
Shaughn Murley
Visions Electronics
Red Deer, Alberta
audioman2007
Copper - Posts: 580
Posted: January 21, 2008 at 6:22 PM / IP Logged
yes the 02 sunfire has a keysense wire. Remove the steering column cover and there should be 3 little little wires to the right of the column. Should be yellow, black and white( if i remember correctly). They go to a grey connecter.
schlever
Member - Posts: 9
Posted: January 22, 2008 at 8:39 AM / IP Logged
Thanks, which one is the keysense in there?
chriswallace187
Gold - Posts: 1,661
Posted: January 22, 2008 at 8:47 AM / IP Logged
None of those are the keysense - those are the Passlock wires. Keysense is lt. green in the same connector with the regular ignition wires.  It shows 12v+ with the key out and goes to 0 when it's inserted.
C Renner's Auto Electronix
schlever
Member - Posts: 9
Posted: January 22, 2008 at 9:13 AM / IP Logged
Thanks Chris. The PLJX has a keysense wire that I never hooked up, so I will give that a try and see if that helps.
kgerry
Platinum - Posts: 3,455
Posted: January 22, 2008 at 4:29 PM / IP Logged
i have never hooked up keysense on a PLJX yet and they have always worked fine...
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
schlever
Member - Posts: 9
Posted: January 23, 2008 at 10:16 AM / IP Logged
Kevin, do you think its a defective unit then?
