alarm going off when remote is shut off
doug.b
Member - Posts: 18
Posted: January 24, 2008 at 10:37 PM / IP Logged
installed mars 33 remote in 2008 ford escape with alarm when the remote shuts off after 10 minutes the alarm goes off or if you try to shut the remote off when the car shuts down the alarm goes off. any help would be appreciated
doug.b
KarTuneMan
Platinum - Posts: 7,056
Posted: January 25, 2008 at 8:59 AM / IP Logged
where did you get your door triggers? are they isolated?
usabuilt
Copper - Posts: 161
Posted: January 25, 2008 at 12:07 PM / IP Logged
Hi Doug, If it was me I would disconnect the door trigger wire and see if the problem is still happening. if it is, then you sould try to diode isolate them as kartune suggested., or if the alarm has diagnostics it should tell you which zone is being triggerd.
Chris Luongo
Platinum - Posts: 3,746
Posted: January 26, 2008 at 8:37 AM / IP Logged
Read the alarm's LED as usabuilt said, and see which "zone" of the alarm is being triggered.
Probably, you're using the domelight as a door trigger, and the car has a feature which turns on the domelight when the engine is shut off (so the driver can see to gather their belongings before exiting the car).
When the domelight turns on, the alarm sees this is a door trigger.
Most modern alarm/start combos are well-designed enough that they ignore the door trigger input for a few seconds at the end of the remote start cycle (and usually at the beginning too).
If yours is an older unit, it probably doesn't have this feature. If your unit is a current-year model, that's an inexcusable error on the engineers' part.
