equalizer
mci_sniper
Member - Posts: 16
Posted: February 04, 2008 at 12:08 PM / IP Logged
Is there any advantage with adding an equalizer to your system if you already have one built into your head unit? Thanks in advance for the info.
Semper Fi
greenbroncoguy
Copper - Posts: 299
Posted: February 04, 2008 at 1:19 PM / IP Logged
That all depends on you and your system. If the processing power in the HU is sufficient for what you want to, or have the ability to tune, then I couldn't see any advantage in adding more adjustability.
But if you need more versatility then adding an external EQ could be beneficial, such as if your headunit EQ will only allow you to adjust the front and rear as a whole, and you have a 3-way system, you may need an external EQ that will allow you to adjust each driver independantly.
Also, keep in mind that introducing another piece of hardware in the signal chain increases the possibility of noise.
Oh, and post up your system components and what you're trying to do and maybe we can offer more advice.
-Matt
mci_sniper
Member - Posts: 16
Posted: February 05, 2008 at 1:28 PM / IP Logged
(2)MA Audio MA120XE
   SoundStorm STW20(tweeters)
   SoundStorm F260S(front)
   SoundStorm F260S(rear)
   Dual XHD6425 (Head unit)
   Insignia NS-A1000 (amp)
   Dual PBA2150 (amp)
in 07 kia spectra
Semper Fi
ninno
Copper - Posts: 56
Posted: March 06, 2008 at 9:32 PM / IP Logged
what stereo harness did you use. what brand and part number. ive tried a couple scoshe ones and the dont fit. anybody know which one to use? 2007 kia spectra with a aux input on the console, if that makes any difference.
