matrix 12.5x, 05 ram 1500
hollisterman36
Member - Posts: 10
Posted: March 19, 2008 at 2:16 PM / IP Logged
anyone?? the alarm will tell me a door is open when infact there is not a door open, also about an hour after arming the alarm will go off flashing that a door has been open, I must've tapped into the wrong wire but I cant figure out where..
icrman
Member - Posts: 14
Posted: March 20, 2008 at 10:03 PM / IP Logged
So then the diode is reversed and the circuit is open?
mikvot
Gold - Posts: 1,043
Posted: March 20, 2008 at 10:16 PM / IP Logged
I get the drivers door pin under the dash. look left of the steering column against the firewall. You will see that huge plug with the plastic white cover. There will be wires coming out the bottom. There is only 1 violet wire in there. That is your drivers door pin.
hollisterman36
Member - Posts: 10
Posted: March 21, 2008 at 12:15 PM / IP Logged
There we go mikvot thank you very much, I will can you possibly tell me why the rear drive door pin wont switch either.. how could've I wired both of these wrong but the passengers right??
mikvot
Gold - Posts: 1,043
Posted: March 21, 2008 at 12:32 PM / IP Logged
Well, the problem with those trucks, is that there are many wires that are colored the same, located in the same area. Very important to test the wires with a multimeter. In the same location I listed the drivers door pin, you will also find a violet/grey(-) that will be your drivers side rear door. make sure you have diode isolated all 4 of your doorpins.
hollisterman36
Member - Posts: 10
Posted: March 21, 2008 at 12:56 PM / IP Logged
is that violet/grey.. is that on the 05 model? or the 04..? Dang lol those wiring diagrams are crap. Haha but okay I have the two wires that I have no idea what they do diode isolated hooked in to my door trigger. I will cut the wires loose on those and hook them to the violet and the violet/gray... thank you again
mikvot
Gold - Posts: 1,043
Posted: March 21, 2008 at 4:06 PM / IP Logged
It might also be violet/orange(-) like mentioned in the earlier post.
