Posted: March 03, 2008 at 5:45 PM / IP Logged
Posted: March 03, 2008 at 7:59 PM / IP Logged
Thursday, May 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
The primary and secondary ignition wires "Key side" are clipped / have nothing attached to them
The car will turn over but not spark / run. I believe that my problem exists in my wiring of the ignition wires. I turn the key to first position and no dash light / nothing. Turn the key to the second / run position and the logicon / AC unit turns on but ho dash lights. I press the clutch and attempt to start and the car will turn over but not start.
Starter is wired through Heavy Gauge relay and appears to be functioning properly.
