relay that works with audio signal?
copcarguy
Copper - Posts: 122
Posted: March 02, 2003 at 6:57 PM / IP Logged
Does anyone know of a relay whereby I could trigger 12 volts using an audio signal?
In other words when an audio signal is present I want to turn on 12 volts to an accessory. Picking up the power wire of the audio accessory is no good because it can be turned on without generating an audio signal. Your replies are much appreciated.
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
the12volt
Administrator - Posts: 3,959
Posted: March 02, 2003 at 7:10 PM / IP Logged
copcarguy
Copper - Posts: 122
Posted: March 02, 2003 at 7:18 PM / IP Logged
Thanks 12volt!
I appreciate your help and I always try to help those I can as well. Take care!
R Jackson
Owner/Installer
Mr_Mike
Posted: March 03, 2003 at 1:26 PM / IP Logged
the12volt wrote:
http://www.davidnavone.com/detail.asp?PRODUCT_ID=N-902
OK, that works with speaker level outputs.  Got any idea for line level outputs?
the12volt
Posted: March 03, 2003 at 1:36 PM / IP Logged
Try a PAC TR-4. Senses voltages as low as 0.8 volts. http://www.go2pac.com
relay that works with audio signal? - Last Post -- posted image. the12volt • Support the12volt.com
Tuesday, February 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
