avital 4400 lights stay on
fpanther
Member - Posts: 6
Posted: March 24, 2008 at 7:51 PM / IP Logged
the idiots that installed my alarm in my brand new 2008 mustang GT messed up the lights, i had them put in the avital 4400 alarm , now the head lights dont go off when you set the alarm the lights dont blink when the alarm goes off the lights dont flash, what can we do to fix this problem does anyone else have this problem. so they rigged  the lights to go off when i shut the car off help please !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
KarTuneMan
Platinum - Posts: 7,056
Posted: March 24, 2008 at 8:26 PM / IP Logged
The headlights or the parking lights?
This is a hard one to F up. Hard to imagine. The tech sheets are PLAIN as day.
Have the "idiots" told you anything about WHY the lights do what they do, and why they don't do what they don't do?
fpanther
Member - Posts: 6
Posted: March 24, 2008 at 8:37 PM / IP Logged
no they told me to go to the dealer and buy a new headlight /foglight switch this is the problem - the light stay on when i drive they should be off- the shut doesnt work in all positions the lights stay on. question when you set your alarm do the lights flash
fpanther
Member - Posts: 6
Posted: March 25, 2008 at 9:38 AM / IP Logged
avital 4400 lights stay on - Last Post -- posted image.i have the avital 4400 need wiring diagram where can i find it , the installer meesed up my lights now they stay on when i set the alarm the lights dont lash, when the alarm goes off the lights dont flash what did they do wrong please help
onthemoney
Posted: March 25, 2008 at 11:16 AM / IP Logged
I would check the fuse on the white wire from the alarm, and check the connection point.
fpanther
Member - Posts: 6
Posted: March 25, 2008 at 11:29 AM / IP Logged
ok ty
techman93
Silver - Posts: 591
Posted: March 25, 2008 at 5:04 PM / IP Logged
If the headlight switch is unplugged it will stay on as well. Could be they did not properly plug it back in. We did a heated seat job on a new 2008 mustang a couple months ago so that is why I know that is what happens with it unplugged. If that isn't the case then they might not have wired the parking lights the right way. In some fords if you use the switch you have to run a relay to break the circuit due to the auto lamp feature. If you do not you can damage the circuit causing the lights to not go off.
The wire I'm test'n isn't doin' what it's supposed to be doin'... I am so glad I printed that tech sheet, with the wrong info.
Do it right the first time... or I might have to fix it for ya
fpanther
Member - Posts: 6
Posted: March 26, 2008 at 11:59 AM / IP Logged
ty, i will so this to the installer - he made me go to the dealer and buy a new headlight/fog light switch . will this help
tedmond
Gold - Posts: 4,610
Posted: March 26, 2008 at 1:54 PM / IP Logged
well if the intsaller messed up, he cant make you go buy parts - he/theshop should be covering all damage done to the car from their install.
fpanther
Member - Posts: 6
Posted: March 26, 2008 at 2:01 PM / IP Logged
they will its a dealer part
