relays for honk honk
richardcaraball
Posted: March 31, 2008 at 2:26 PM / IP Logged
I'm look for a relay setup for alram with out horn honk output
using flashing lights output and siren output
the12volt
Administrator - Posts: 3,959
Posted: March 31, 2008 at 2:39 PM / IP Logged
Here's one with just the siren output: https://www.the12volt.com/relays/page4.asp#lf3 ....connect to horn instead of lights. You could also use a positive light flash output from your alarm instead of the constant 12V input to terminal 87 and omit the flasher.
relays for honk honk - Last Post -- posted image. the12volt • Support the12volt.com
richardcaraball
Posted: March 31, 2008 at 10:10 PM / IP Logged
thanks i try that
