air horn with car alarm?
pitdawg
Member - Posts: 6
Posted: April 01, 2008 at 10:22 AM / IP Logged
Hi guys  im new here..
i need help i have a ungo (clairon) alarm that has a (-)  wire to run to horn relay to make the horn honk when the alarm goes off.
I have a 97 tahoe i found the horn relay in the relay box under the hood.. Do i hook it to that? Or  Do i have to have a hole diffrent relay i would buy form parts store or something?  If i could hook it up to the horn relay  thats already factory in the truck, What prong would i have to tap into.. Please help.. Im stumped..
KarTuneMan
Platinum - Posts: 7,056
Posted: April 01, 2008 at 12:02 PM / IP Logged
There is a black wire in the harness from the steering column, it's a negative trigger so you should be able to test it and wire directly without a relay.
pitdawg
Member - Posts: 6
Posted: April 01, 2008 at 1:17 PM / IP Logged
Ok so i just find the black wire in steering,,, and wire the - alarm horn wire to that black wire in steering?
Wont there be a bunch of black wires in steering colum?  should i just tap in to all of them intill the horn starts honking?
KarTuneMan
Posted: April 01, 2008 at 2:59 PM / IP Logged
TEST all connections.
If you don't have a multimeter get one. borrow one if you must.
Your truck is worth far more than the cost of this tool you will use for the rest of your life.
Safety first, but if you just wanna go tapping into black wires willy-nilly     have at it.
The horn wire will go to ground when you honk it.
pitdawg
Member - Posts: 6
Posted: April 01, 2008 at 3:17 PM / IP Logged
ok  so i test all the connections... how do i know what wire it is.. Im sure the meter wont say this is the wire you need... stick with me.. Im a lil confused, I need detail. thanks again for your help..
pitdawg
Member - Posts: 6
Posted: April 02, 2008 at 12:53 PM / IP Logged
Can anyone else help me i dont  think that guys coming back..
another-kelly
Silver - Posts: 618
Posted: April 02, 2008 at 6:45 PM / IP Logged
go buy a digital multi meter and test for continuity to ground on the proposed black wire when honking the horn
