another led wiring
iiixtremeiii
Posted: April 15, 2008 at 10:10 AM / IP Logged
I've been reading a lot about wiring LED"s and am a little confused.  Here is what I want to do.  I've got some plexi in my door panels that I've sanded and I want to light up.  And I've also got some plexi in the trunk that I want to light up also.  If I have like 10 LEDS in each door and then 10 in the back so that's a total of 50 LED's.  Can I hook all of them up to the same switch or do I need to use multiple switches?
For the resistors I'm using the following website as a reference for my resistors
http://led.linear1.org/led.wiz
For the quantity do I need to put 50 total or 10 total?  I'd like to have it all hooked up to one switch if possible.  But if I can't then multiple switches is ok and I think that would answer my question to 10 LED per switch but just wanted to I guess find out if I could connect them all to the same switch.
Thanks in advance
almulder
Member - Posts: 10
Posted: April 16, 2008 at 5:48 PM / IP Logged
I would say it would depend on the switch. The switch must be able to support the load (amp draw) if it does one switch would work. I have set up many different setups where LED's are used and have had over 100 set up to one switch (Relay).
So YES if the switchs supports the load.
Sunday, December 21, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
