wiring my new amps and batteries
mazzasec
Copper - Posts: 93
Posted: May 19, 2008 at 11:59 AM / IP Logged
Well I just got a kinetik 2400 for my rear. How close do I need to put the fuse? I think I got about 17 inches of wire after the fuse going to the battery. Also my amp is directly next to my battery. Do I have to fuse the wiring coming off the battery into the amp if its a short distance? ill get a pic up
wiring my new amps and batteries - Last Post -- posted image.
Big Dog
Gold - Posts: 1,265
Posted: May 20, 2008 at 1:27 PM / IP Logged
Put the fuses as close as humanly possible to the batteries this includes a fuse for the amp.
Prepare your future. It wasn't the lack of stones that killed the stone age.
chillin420
Copper - Posts: 236
Posted: May 20, 2008 at 8:02 PM / IP Logged
within 18 inches of the battery is all that is recommended.
BIG DOG   how do you fuse the amp at the battery?  the fuse near the battery is for the wire. thats all the fuse on the amp is for the amp.  you can put in a fused distro block to "fuse" the amp a little more.  but still dont see how you fuse the amp on the wire......
you can do it....
advanced MECP, lol does it really matter....
patience is a virtue
daboss593
Copper - Posts: 154
Posted: May 21, 2008 at 5:45 AM / IP Logged
i norm fuse the batt and then use a matched fuse dist block. i rarely have an issues.wiring my new amps and batteries - Last Post -- posted image.
OWWWWWWWWWWW you said you discharged the cap!
Big Dog
Gold - Posts: 1,265
Posted: May 21, 2008 at 7:48 AM / IP Logged
to chillin420 .....like daboss sez....battery.....distro block.....fuse
18 inches is the norm but it all depends on where the cables sit or pass. If it's all wood and absolutely no metal then you can be a little more flexible and reasonable. Use good judgement.
How do you like my smokey? Had some fun with Corel. wiring my new amps and batteries - Last Post -- posted image.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
