cycle on off on off.
jlmccuan
Member - Posts: 8
Posted: May 23, 2008 at 12:13 AM / IP Logged
I need to cycle a circuit On x seconds, then Off x Seconds and then repeat indefinately.  I have some 528T's and regular Bosch relays.  I would like to set it up so that one timer controlled the time On and the other time Off.  I need to have this running tomorrow.  Thanks, Jim
Jim
hotwaterwizard
Silver - Posts: 1,350
Posted: May 23, 2008 at 1:38 AM / IP Logged
Here is what I came up with!
Use the extra Orange or Brown for the load depending on what output you need.
Hook a light bulb to each to see the outputs WigWag
cycle on off on off. - Last Post -- posted image.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
jlmccuan
Member - Posts: 8
Posted: May 23, 2008 at 7:39 PM / IP Logged
I hooked it up today. All I had to change was the top relay orange and brown wires had to be swapped.  It works great, but for some reason, the most delay I can get is 60 seconds.  As more detail, I'm using it to run a small pump, max amps 5.0
Thanks for the help,
Jim
Jim
hotwaterwizard
Posted: May 24, 2008 at 1:05 AM / IP Logged
Explain what mod you had to do better.
Did you switch the orange of timer 1 to the trigger of timer 2 and the brown of timer 2 to the trigger of timer 1?
Modify the Drawing in ms paint and post it.
Stockton California
hotwaterwizard
Posted: May 24, 2008 at 1:07 AM / IP Logged
See Jim I have never even seen or used one of these timers . I'm just going by the instruction sheet.
528t_timer_instructions.pdf
Stockton California
jlmccuan
Member - Posts: 8
Posted: May 24, 2008 at 8:46 PM / IP Logged
All I had to do was use the orange normally closed output from timer 1 attached to timer 2's trigger instead of the brown wire as shown in your diagram.
Any ideas as to why I'm only getting 60 seconds instead of 90 seconds for my max time?
Jim
hotwaterwizard
Posted: May 26, 2008 at 6:45 PM / IP Logged
So this is the final Drawing?
Stockton California
jlmccuan
Member - Posts: 8
Posted: May 27, 2008 at 12:41 PM / IP Logged
That is as built and running.  The only problem is that I can't get a full 90 second delay, but it's working out OK.
Jim
hotwaterwizard
Posted: May 28, 2008 at 12:26 AM / IP Logged
You could add 2 more into the mix and get twice the delay.  Or just buy a repete timer that will do the job.
http://www.aedwis.com/nationalcontrols.html
Stockton California
