power cable types
silentblackhat
Copper - Posts: 138
Posted: June 01, 2008 at 5:08 PM / IP Logged
Hey guys I have a question about some power cable.
I have about 22ft of 4 gague power wire that I am getting from a friend. Its the blue "Kolossus Kable" from Knukonceptz.com
It says: "Kolossus Kable 4AWG Blue Power Wire features 2058 Tinned Strands of Pure Oxygen Free Copper. "
What does "tinned copper" mean? Obviously its tinned copper but how good is it? Does it have any advantages or disadvantages?
Im planning on using this for "The Big Three" since 150 amps is the max of the cable, which is way less than what my alternator puts out and is also less than what my car will ever need with my system.  I am also planning on using this as my main power cable for my JL 500/1 amp.
Is this good cable to use for both applications?
haemphyst
Platinum - Posts: 5,059
Posted: June 01, 2008 at 7:20 PM / IP Logged
It's fine. Use it, especially if it's free!
From dictionary.com:
12. Metallurgy.
    a. to cover or coat with tin.
    b. to coat with soft solder.
Platinum - Posts: 13,726
Posted: June 01, 2008 at 9:15 PM / IP Logged
Your basic speaker wire with one copper colored conductor and the other conductor is silver in color, the silver conductor is tinned copper.  The strands are coated with solder to give it a silver color.
jmelton86
Gold - Posts: 1,228
Posted: June 02, 2008 at 7:17 PM / IP Logged
You said the 4g handles 150amps max, right? You also said you're planning on doing the Big3 with this, yet your alternator puts out more than 150amps? You also said your system will need larger than 4g.
I'd double-up each wire, for the Big3 AND your actual amplifier power cable. Just be sure to fuse EACH positive wire AT the power source(s) with a 150amp or smaller fuse.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
jmelton86
Gold - Posts: 1,228
Posted: June 02, 2008 at 7:24 PM / IP Logged
Big3 in 1/0G
1/0G to GTO14001
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
