purchasing a fi btl
s_goodie
Member - Posts: 44
Posted: July 29, 2008 at 2:55 AM / IP Logged
i am about to purchase a Fi BTL and im not sure how to order it it hasmany differnt ways to do it i can get it 1 or 2 ohm and i also can get a P Chamfer and i also can get cooling and i also can get hixm coil and i alos can get daily or spl and i can get induct heating ring and ialso can get  it universal or not how should i order it PLEASE HELP
Stuey BABE
s_goodie
Member - Posts: 44
Posted: July 29, 2008 at 4:41 AM / IP Logged
BTL18
DUAL 1 | DUAL 2
Fs: 00.0 Hz | 00.0 Hz
Re: 0.7 Ohms/coil | 1.5 Ohms/coil
Qms: 0.00 | 0.00
Qes: .00 | .00
Qts: .00 | .00
Mms: 000g | 000g
Cms: 0.00mm/N | 0.00mm/N
Sd: 1210cm^2 | 1210cm^2
Vas: 00.0 l | 00.0 l
Spl: 00.0dB 1W/1m | 00.0dB 1W/1m
Bl: 00.0 N/A | 00.0 N/A
Xmax: 16mm * | 16mm *
Rms: 2000W * | 2000W *
Sealed box: N/A cuft | N/A cuft
Ported box: 5-10cuft | 5-10cuft
Sub OD: 18.500” | 18.500”
Cut ID: 16.750” | 16.750”
Mounting depth: 9.750” * | 9.750” *
Displacement: 0.26cuft * | 0.26cuft
Stuey BABE
aznboi3644
Gold - Posts: 2,600
Posted: July 29, 2008 at 8:10 PM / IP Logged
options depends on how much power you are going to feed the subwoofer
s_goodie
Member - Posts: 44
Posted: July 29, 2008 at 10:17 PM / IP Logged
probably around 1500 or 1600 watts hifonics amp
Stuey BABE
aznboi3644
Gold - Posts: 2,600
Posted: July 31, 2008 at 10:55 PM / IP Logged
well with that power a stock BTL would do. There is no need for extra options.
