tach wire, 2000 crown victoria
cb11044
Member - Posts: 18
Posted: July 29, 2008 at 4:20 PM / IP Logged
I installed a clifford 50.5x r/s in my 2000 crown vic.  Right now its setup to voltage check, because I cant find my tach wire.  Does anyone know exactly where it is direct techs says its under hood at the pcm (WHITE/ pink)
Ive had no luck so far ive found like 3 wires that are WHITE/ pink, but when I try to learn the tach the led never turns on.
Any how with voltage check if I have my a/c on the car shuts down after 10 secs.  the manual says if this happens to hook tach wire.  I live in texas so yall know how hot it gets down here.  I need my a/c to turn on when I remote start.
thanks
jmsounds
Copper - Posts: 99
Posted: July 30, 2008 at 11:30 AM / IP Logged
i work on crown vic there is no tach wire in this cars they use data for tack signal the best option is voltage check, it should not shut down if starts you probably did not program it for voltage yet and also if it doesn't start in the first try try programing the crank a litle longer
ayalahomero
Copper - Posts: 52
Posted: July 31, 2008 at 1:14 AM / IP Logged
thanx, Well it starts on voltage check (thats how I have it now) when I have my a/c off, no problems like that.
When I leave my a/c on it will start, but shut down after 10 sec., Iv'e energized ign, 2nd ign, acc., but nothin on 2nd acc.
homero ayala
jmsounds
Copper - Posts: 99
Posted: July 31, 2008 at 11:28 AM / IP Logged
have you check to see if you have the voltage to high or low it probably dies if the voltage is set to high when it senses the voltage
drops too low when the ac kicks in try programing maybe it work
kgerry
Platinum - Posts: 3,455
Posted: July 31, 2008 at 3:13 PM / IP Logged
i show tan/green or tan/blue at the coil
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
ayalahomero
Copper - Posts: 52
Posted: July 31, 2008 at 11:52 PM / IP Logged
I cant remember if I have it set on low or high, but I'll check wussup with that...
homero ayala
