08 scion xd, alarm/remote start wiring
smokescreen024
Posted: August 09, 2008 at 12:03 PM / IP Logged
Hi I'm looking for wire color and location for an 08 scion XD the XB and TC have lots of coverage in vehicle wiring but the XD is lacking  i think partly due to the name confusion. some one started to adress the issue back in march but  the discussion narrowed to only door locks nice pic though. I would love to have a complete list that they could post in vehicle wiring any help is greatly appreciated!
Platinum - Posts: 13,726
Posted: August 09, 2008 at 9:37 PM / IP Logged
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Battery YELLOW (+) IGNITION SWITCH HARNESS 08 scion xd, alarm/remote start wiring - Last Post -- posted image.
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Ignition 1 PINK (+) IGNITION SWITCH HARNESS
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Ignition 2 GREEN (+) IGNITION SWITCH HARNESS
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Accessory 1 WHITE (+) IGNITION SWITCH HARNESS
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Starter 1 BLACK (+) IGNITION SWITCH HARNESS 08 scion xd, alarm/remote start wiring - Last Post -- posted image.
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Anti-Theft Type UNIVERSAL IMMOBILIZER
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Anti-Theft Descript THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Key Sense YELLOW (-) IGNITION SWITCH HARNESS
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Tachometer RED (AC) AT ECM MODULE
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Speed Sense VIOLET (AC) RADIO HARNESS 08 scion xd, alarm/remote start wiring - Last Post -- posted image.
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Parking Lights GREEN (+) AT VEHICLE FUSEBOX 08 scion xd, alarm/remote start wiring - Last Post -- posted image.
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Low Crr. Pk Lights WHITE (-) AT VEHICLE HEADLIGHT SWITCH
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Brake Lights GREEN (+) AT SWITCH ABOVE BRAKE PEDAL
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Reverse Lights RED (+) AT VEHICLE FUSEBOX 08 scion xd, alarm/remote start wiring - Last Post -- posted image.
08 scion xd, alarm/remote start wiring - Last Post -- posted image.Horn LIGHT GREEN (-) AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH 08 scion xd, alarm/remote start wiring - Last Post -- posted image.
Notes are as follows.
Battery wire at ign harness is fused at 25 amps.  From my own personal experience with an XB, get this at the battery, not the ignition switch harness.
Starter 1   there are 2 black wires,  test to make sure you have the right 2 and connect both.
Speed sense   ALSO PIN AT SKID CONTROL ECU UNDER HOOD
Parking lights   30 PIN PLUG PIN #29
Reverse lights  30 PIN PLUG   PIN 30
Horn   ALSO BLACK IN HARNESS AT STEERING COLUMN
tmrepp
Member - Posts: 19
Posted: August 11, 2008 at 12:28 PM / IP Logged
There's no immobilizer antenna setup on the key cylinder in the xD either..I installed my own, very straight forward. Door triggers were a pain in my butt. Let me know if you need me to post what I have on them. I'd have to look it up, or go out and write down colors. hah
I tapped into all 5 door triggers behind the little compartment above the fuse box to the left of the steering wheel, and diode isolated them all.
bobolinko
Posted: September 22, 2008 at 2:51 AM / IP Logged
Hello, Tmrepp
I amd trying to install an aftermarket alarm in my 08 xD, and have not been able to find any info on wiring, etc.
It's making the install look rather bleak.  If you can, would you be so kind as to tell me where those points behind the driver side coin tray that you referred to as the door lock wiring ?
a picture would be nice, or....  if you have a cell phone,
you could call me. 808--383-4142 :>)
Thanks, and Aloha from Hawaii !
Posted: September 23, 2008 at 9:20 PM / IP Logged
     All Door Trigger          PINK          (-)          AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
     Domelight Super          PINK          (-)          AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
     LF Latch          RED          (-)          AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
     RF Latch          GREEN          (-)          AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
     LR Latch          BLUE          (-)          AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
     RR Latch          BLUE          (-)          AT BODY CONTROL MODULE TO BEHIND FUSE PANEL BEHIND DRIVERS SIDE OF DASH
     Trunk Trigger          LIGHT BLUE          (-)          AT FUSE PANEL BEHIND DRIVERS SIDE OF DASH
     Hood Trigger          WHITE          (-)          AT SWITCH UNDER HOOD
     Low Crr Pk Lights          WHITE          (-)          AT VEHICLE HEADLIGHT SWITCH
