isobaric sealed box
97srad750
Posted: August 28, 2008 at 7:27 AM / IP Logged
I was thinking of trying this out. https://www.the12volt.com/caraudio/boxes2.asp#2 . My question is does the box need what the airspace would be for 1 sub or for 2 subs? Do these boxes sound good? Thanks for the help.
DYohn
Platinum - Posts: 10,741
Posted: August 28, 2008 at 8:14 AM / IP Logged
The enclosure size for isobaric loading is 1/2 what is normally required for 1 woofer.  They sound just like any other sealed system.
97srad750
Posted: August 28, 2008 at 9:42 AM / IP Logged
So my 10 calls for .5, then I only need .25 for both woofers?
Last one. The 2 10's will sound like 2 10's in the isobaric setup.
DYohn
Posted: August 28, 2008 at 9:55 AM / IP Logged
First statement: that's correct.  Second statement: I have no idea what you mean.
haemphyst
Platinum - Posts: 5,059
Posted: August 28, 2008 at 11:09 AM / IP Logged
In answer to your second question: If you have a TOTAL QUANTITY of two 10's, clamshelled (face to face), then you will have the OUTPUT of one 10. You only have one radiating surface. Do the math. The ONLY difference is the volume required by the woofer. One radiating surface, two woofers. Output of one woofer, volume of 1/2 of one woofer.
To get the output of two 10's in isobarik configuration, you need a QUANTITY of four 10's - two clamshelled, and the other two clamshelled - for the radiating surface of two 10's.
97srad750
Posted: August 28, 2008 at 12:26 PM / IP Logged
Thanks fellas. That answered it.
