kinetik 2400 on stock alternator?
bumpinexploder
Copper - Posts: 265
Posted: September 24, 2008 at 8:42 PM / IP Logged
hey i got a new car and am doing a brand new system. right now u have 2 cvr 12s in a custom ported box with the trunk sealed off and the ports facing in the cab. the lights dim like crazy from my direct d1200 amp only pushin 400 rms @ 2 ohm. i am going to trade some stuff to a friend for a kinetik 2400 that he has. question is willl that be enough to hold my amp without getting a new alternator? its only a 65 amp on my zx2.
Pioneer DEH-400UB
Kicker 150.2 mids/highs amp
MB Quart fsa 216 front stage
AudioPipe gd-6001 mono amp
AUDIOQUE SD 15S PREFAB BOX!
C&D Technologies Battery, 1500 CCA, 134 amp storage
149.5 DB's
alex1711
Member - Posts: 6
Posted: September 28, 2008 at 8:51 PM / IP Logged
I was going to ask the exact same question, actually. Except my stock alt puts out 90 amps. Hopefully someone will answer.
macq32
Posted: September 29, 2008 at 7:39 PM / IP Logged
Ditto, looking at a 2400 for my stock 90a alternator
bumpinexploder
Copper - Posts: 265
Posted: September 29, 2008 at 7:58 PM / IP Logged
well dang all lookers and no knowledgable advice lol.
Pioneer DEH-400UB
149.5 DB's
KarTuneMan
Platinum - Posts: 7,056
Posted: September 30, 2008 at 11:47 AM / IP Logged
Ask THIS guy.
audiocableguy
Copper - Posts: 630
Posted: September 30, 2008 at 11:30 PM / IP Logged
No matter what battery, you must replace the energy used ie Alternator. If you suck out 65 amps, you have a 90 amp Alt. This assumes that the alternator will put rated amperage hot. That leaves 35 amps to run fuel pump, vehicle computer, lights etc. something's got to give. Alternator failure, Premature battery failure or both. True, the amp will not be a continuous load but with such a small Alt. any additional load is going to be an issue. A kinetik might last a little longer than most but it's still not dealing with the problem.
bumpinexploder
Copper - Posts: 265
Posted: October 01, 2008 at 7:44 AM / IP Logged
well how big alt should i get then? i have a directed 1200 with a 60 amp fuse on it.
Pioneer DEH-400UB
149.5 DB's
