05 dodge 2500
projnostic
Posted: September 29, 2008 at 7:36 AM / IP Logged
Was installing back up lights using reverse wire(purple) for trigger switch to relay and trailer battery power constant power(trailer tow connector white red stripe)when plugging into relay something popped and now trailer wire is no longer hot
kassdog
Copper - Posts: 257
Posted: September 30, 2008 at 5:18 PM / IP Logged
Have you checked all the fuses. If the hitch was put on aftermarket you might have to go under the dash to find the fuse.
projnostic
Posted: September 30, 2008 at 9:36 PM / IP Logged
Ok ran 12gage wire from battery to power the relay.Thinking maybe drawing too much juice for the lights popped the wire(trailor power) but all fuse in the fuse box are good.
Under dash I'm not seeing any fuses at all?
Any more thoughts? Thanks for the reply.
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
