1995 saturn sl, power lock
bengerman
Posted: November 10, 2008 at 5:19 AM / IP Logged
I have a 1995 saturn SL. Currently, i have power nothing, but i do have an aftermarket alarm (hornet 740t)
I'm looking to install power door locks, and i already have the actuators and switches off another saturn SL. The actuators have a lock and unlock wire, the switch has a lock, unlock, and ground.
I'm trying to figure out how to wire the actuators, adn i would like them to be activated by both the switches in my car and the alarm system.
bengerman
Posted: November 10, 2008 at 5:25 AM / IP Logged
i forgot to mention, i could not get the factory relay setup, so i need to use standard relays instead.
ckeeler
Gold - Posts: 1,461
Posted: November 10, 2008 at 12:24 PM / IP Logged
just go to the door lock/relay section on this site. use the wiring diagram for adding aftermarket actuators using relays. it will explain how to wire them up. tie in the unlock/lock wires from your switches to the same wires that come from the alarm to trigger the relays that way the switches work as well as the alarm to lock/unlock the doors.
bengerman
Posted: November 11, 2008 at 11:55 AM / IP Logged
cool thanks!
