navigation in 06 silverado
leoc22
Member - Posts: 10
Posted: November 20, 2008 at 12:17 PM / IP Logged
Hi i need help installing a clarion nax980hd on a clarion vrx785bt in a 2006 chevy silverado lt extended cab. the instructions are asking me to find the EC(engine control computer) and find the vehicle speed signal cable. I also need to find the reverse gear lamp. can anyone please help thanks would really appreciate it
Mike M2
Platinum - Posts: 2,652
Posted: November 20, 2008 at 5:50 PM / IP Logged
You can find the VSS right next to the radio in the cluster. Just pull the 4 7mm screws holding the speedometer in place and look for the GREEN / WHITE wire in the only plug back there. The reverse light wire is in the BCM, which is located under the steering column. It in the black plug, pin f, light green wire....
Mike M2
Tech Manager
CS Dealer Services
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
