2008 mitsubishi galant, alarm/remote start
xtreme571
Posted: December 05, 2008 at 12:17 PM / IP Logged
Hey guys, a newbie here. I'm looking for wiring diagram for 2008 Galant to install a remote starter and security system.
Thanks.
Once a wise man said...I forgot what he said.
another-kelly
Silver - Posts: 618
Posted: December 05, 2008 at 2:01 PM / IP Logged
     Battery          BLUE / YELLOW          (+)          IGNITION SWITCH HARNESS
     Ignition 1          BLACK/ WHITE          (+)          IGNITION SWITCH HARNESS
     Accessory 1          BLUE/RED          (+)          IGNITION SWITCH HARNESS
     Accessory 2          BLUE/BLACK          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLACK / YELLOW          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          UNIVERSAL IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLUE/RED          (OPEN)          IGNITION SWITCH HARNESS
               THIS WIRE RESTS AT GROUND AND GOES TO AN OPEN CIRCUIT ONCE THE KEY IS INSERTED
     Tachometer          YELLOW/RED          (AC)          AT INJECTOR #1
               ALSO YELLOW/BLUE AT INJECTOR #2
     Speed Sense          GREEN/ YELLOW          (AC)          AT PCM MODULE BEHIND DRIVER HEADLIGHT
     Parking Lights          GREEN / WHITE & GREEN/ ORANGE          (+)          IN HARNESS IN DRIVER SILL PANEL
               MUST USE BOTH WIRES AND DIODE ISOLATE EACH WIRE,
     Brake Lights          GREEN          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          RED / BLUE          (+)          IN HARNESS IN DRIVER SILL PANEL
     Horn          LIGHT GREEN          (-)          AT MODULE UNDER DRIVER SIDE DASH
Power Unlock          LIGHT GREEN/ RED          (-)          IN HARNESS IN DRIVERS KICKPANEL
     PowerLock          VIOLET          (-)          IN HARNESS IN DRIVERS KICKPANEL
Trnk Release          GREEN / WHITE          (REV)          AT MODULE UNDER DRIVER SIDE DASH
All Door Trigger
               USE ALL DOOR TRIGGERS AND DIODE ISOLATE EACH WIRE
     Domelight Super          RED / GREEN          (-)          AT VEHICLE FUSE BOX
     LF Latch          LIGHT GREEN          (-)          AT VEHICLE FUSE BOX
     RF Latch          YELLOW          (-)          AT VEHICLE FUSE BOX
     LR Latch          ORANGE / BLACK          (-)          AT VEHICLE FUSEBOX
     RR Latch          ORANGE / BLACK          (-)          AT VEHICLE FUSE BOX
     Trunk Trigger          RED          (-)          AT MODULE UNDER DRIVER SIDE DASH
     Alarm Disarm          RED / GREEN          (-)          AT THE ETACS MODULE UNDER DRIVER SIDE DASH
     Alarm Arm          LT.GREEN/ BLACK          (-)          AT THE ETACS MODULE UNDER DRIVER SIDE DASH
xtreme571
Posted: December 05, 2008 at 4:05 PM / IP Logged
Thank You very much
