keyless entry problems
alxmrt
Member - Posts: 14
Posted: December 13, 2008 at 3:31 PM / IP Logged
Ok i'm in the middle of installing a remote start/keyless entry on a 2003 F250 diesel. When the unlock/lock wire is plugged into the brain the door unlock/lock switch does not operate either does the keyless entry work.
Unplug the wire from the brain and door switch starts working and if i touch the unlock wire from the brain to the unlock wire in door jamb it will unlock with out using remote. Same with the lock wire unless both are connected and nothing happens.
Any ideas?
KarTuneMan
Platinum - Posts: 7,056
Posted: December 13, 2008 at 10:04 PM / IP Logged
Have you determined the type of locks the truck has?
rev. polarity..... negative trigger  ??
alxmrt
Member - Posts: 14
Posted: December 13, 2008 at 10:18 PM / IP Logged
its a negative trigger on both truck and keyless module
t&t tech
Platinum - Posts: 2,622
Posted: December 14, 2008 at 11:08 AM / IP Logged
i've never done that particular vehicle, but i encountered this a couple times, i resolved it by placing a three amp diode on each wire, bar facing the keyless entry side, that way only  a negative signal flows, all others are filtered. just a thought.
ckeeler
Gold - Posts: 1,461
Posted: December 14, 2008 at 12:06 PM / IP Logged
^^exactly the right procedure to fix this. good job t&t!
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
