compustar 2w9000fmr clicking noise
isleepinadrawer
Posted: December 20, 2008 at 8:09 PM / IP Logged
Hi, just got this installed
When im driving around, from time to time i hear a clicking noise...like a relay being switched.
It sounds like the same noise when i put the car into reservation mode.
anyone have this problem before? i should probably bring it back to the installer
jinstall
Copper - Posts: 67
Posted: December 20, 2008 at 10:46 PM / IP Logged
could be a relay clicking when you hit the brake... not sure. I'm actually in the process of installing a comp right now and it's a bit of a noisy brain. the pro series are much quieter.
isleepinadrawer
Posted: December 20, 2008 at 11:34 PM / IP Logged
i'll try driving it around and see if i can reproduce the relay action when i do something.
dswift
Copper - Posts: 396
Posted: December 21, 2008 at 10:35 PM / IP Logged
Sounds like the E-brake is seeing ground on constant. When you push the foot brake it does Takeover. So if you hold the foot brake and turn the key to the off position. The car will turn off. EVen with the E-brake up, You need to take it back to your installer for a check.
"dont ground out!"
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
