06 pt cruiser keyless entry
customworks
Member - Posts: 11
Posted: December 22, 2008 at 4:30 PM / IP Logged
Having trouble with unlock from Prestige APS45B keyless entry.  Lock working good through 1K ohm resistor. Using 250 ohm resistor on unlock with no luck. I can get it to unlock by swapping door lock wires out of keyless entry module and hitting lock button on remote, but then no lock. This is on a 2006 PT Cruiser. Using light GREEN/ dk. green single lock wire.
Any suggestions???
customworks
soundnsecurity
Gold - Posts: 2,720
Posted: December 22, 2008 at 4:51 PM / IP Logged
can you test the unlock output from the keyless module you are installing? if that output is busted after all then you might be able to rig something to the 2nd unlock or factory disarm wire if your unit has these. also you might need to use relays as a last resort.
customworks
Member - Posts: 11
Posted: December 22, 2008 at 5:53 PM / IP Logged
Got it. Thanks. By mistake, I was on the 2nd door unlock output (RED / blk) instead of unlock output (red).
customworks
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
