08 jeep wrangler disarm wire
coyote72
Member - Posts: 17
Posted: December 30, 2008 at 9:44 PM / IP Logged
Hey guys,
Looking for the color & location of the factory disarm wire (and resistor value if needed).
I have installed a Hornet 569T remote start & for the "Alarm Disarm" the Directed wiring sheet says Factory Remote Only where the color/location should be.
For "Disarm No Unlock" it says Sentry Key Immobilizer.
So I installed a Directed 556cw bypass for it and assumed this would also disarm the alarm as well as bypass the Sentry Key system...I guess I was wrong.
For me to start the vehicle I must first hit "unlock" on the factory key fob & then the remote start button on the 569T key fob to start the car. I can then hit "lock" and the car continues to run.
If I do not hit the unlock button before the start button the alarm/horn sounds.
I'd sure like to find that darned disarm wire if it exists.
Thanks in advance.
Ween
Platinum - Posts: 1,368
Posted: December 30, 2008 at 11:19 PM / IP Logged
hi,
you'll need to have the vehicle see the keysense resistance  (approx 8.5K ohms) on the PURPLE / brown at the ignition key switch and the immobilizer to disarm the alarm.  diode isolate off of the factory disarm lead of the remote start.
mark
coyote72
Member - Posts: 17
Posted: December 30, 2008 at 11:30 PM / IP Logged
Thanks Mark,
Just one more clarification please. I have the mux wire interfaced wired as shown on the diagram below. Which side of the "cut" do I want to hook onto or does it even matter?
08 jeep wrangler disarm wire - Last Post -- posted image.
Thanks again.
coyote72
Member - Posts: 17
Posted: December 31, 2008 at 7:14 AM / IP Logged
Also Mark...
What tye of diode and which direction should the band face.
Thanks.
Ween
Posted: December 31, 2008 at 8:11 AM / IP Logged
the car side of the mux wire is fine, and 1N4001 or equiv. diodes, bands face the disarm lead of the rem start.
coyote72
Member - Posts: 17
Posted: December 31, 2008 at 2:10 PM / IP Logged
Help again...
When I soldered a 8.2K ohm resistor to the 1N4001 diode and test across both I get 2.5M ohms (which is about the same as the diode by itself).
Is this correct or am I doing something wrong? And is 8.2K close enough to 8.5K to work?
Thanks.
coyote72
Member - Posts: 17
Posted: December 31, 2008 at 2:12 PM / IP Logged
Oh & when I test the other way i get no reading.
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
