2005 grand cherokee remote start problems
skidoo6100
Posted: January 03, 2009 at 10:15 PM / IP Logged
Installed a Astroflex unit on a 05 Grand Cherokee.  Everything works but the parking lights and horn.
I did the solder onto pin 1 of both the parking light relay and horn.  When checked by grounding pin 1, it does trigger the relay and acctivate the lights.  Why is the negative pulse off the remote start unit not trip the relay?  Should i run a separte relay for both of them to get a clean negative signal, do they need a resistor?  And yes remote starter parking light feed was switched to negative.
Any ideas?  Thanks in advance.
djfearny2
Silver - Posts: 810
Posted: January 03, 2009 at 10:34 PM / IP Logged
us the negative hazard wire located at the scm module. one wire
The SCM (Steering Column Module) is in the steering column. for parking lights.
horn is dak GREEN/ orange horn or ipm connector pin 35
The IPM (Integrated Power Module) is on the driver fender, behind the battery.
Jon
Installer/Help Technician
---coral springs florida---
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
