overpowering or not?
ernk29
Member - Posts: 33
Posted: January 07, 2009 at 12:25 PM / IP Logged
I have a diamond audio d3 ten thats rated at 400rms 800max, i plan to run my alpine mrp-650 on it, i'm setting it up for 2ohms which means my amp will be at 600rms, how will my D3 react to 600rms? will it blow? or could it handle it due to 800max?
soundnsecurity
Gold - Posts: 2,720
Posted: January 07, 2009 at 12:36 PM / IP Logged
you should be fine just dont go too heavy on the bass boost
whiterob
Copper - Posts: 351
Posted: January 07, 2009 at 12:40 PM / IP Logged
You can use that amp but you will need to set the gain correctly. If you do that then you will be fine and will not overpower your sub. To find out how to set the gain correctly use the search function on this forum. There is a tutorial on here that will explain it to you.
The max rating means nothing. They have no real use except for marketing.
You also need to put the sub in the correct enclosure. If it is in the wrong enclosure you can still damage your sub.
haemphyst
Platinum - Posts: 5,059
Posted: January 07, 2009 at 9:25 PM / IP Logged
I say: "beat it 'till it CRIES"! LOL
ccityroadshop
Copper - Posts: 76
Posted: January 08, 2009 at 8:01 PM / IP Logged
haha too much info
mustang GT convertible with lots of performance mods... Alpine M500 amp with sealed enclosure, 10 inch kappa perfect, clarion cz500 head unit, kicker ks speakers all around
