viper 791xv programming
newinstaller
Copper - Posts: 160
Posted: January 19, 2009 at 2:04 PM / IP Logged
Hello,
I install also of Viper 791XV and noticed there is no " unlock before start , lock after start " Program feature.
Is there a way to program this as it is not listed in the book. Mabye someone has a nice trick  :)
Thanks a bunch
robertsc
Copper - Posts: 337
Posted: January 19, 2009 at 2:23 PM / IP Logged
you can use disarm wire to unlock and negative starter output to relock
with a diode of course
JWorm
Platinum - Posts: 2,208
Posted: January 19, 2009 at 4:27 PM / IP Logged
Connect the disarm and unlock wires of the Viper to the unlock in the car, connect the lock and rearm wires of the Viper to the lock wire of the car.
robertsc
Copper - Posts: 337
Posted: January 19, 2009 at 9:35 PM / IP Logged
whats the vehicle?
personally on a vehicle that needs to be unlocked before start
i use starter output to lock it
i leaves the vehicle unlocked for the least amount of time
newinstaller
Copper - Posts: 160
Posted: January 21, 2009 at 9:13 AM / IP Logged
It is a 05 Mazda 3
need to unlock then start then after start needs to locks up again
The Viper 791XV doe snot have that option
soundnsecurity
Gold - Posts: 2,720
Posted: January 21, 2009 at 2:18 PM / IP Logged
really? mine does and it is pretty old. the wires aren't on the main harness, it's on the H2 harness. colors are GREEN / WHITE (-) factory rearm and light GREEN/ black (-) factory disarm.
just hook the fartory rearm wire to your lock wire and the disarm to your unlock
another-kelly
Silver - Posts: 618
Posted: January 21, 2009 at 11:14 PM / IP Logged
why do you need to unlock then re-lock? can't just use the disarm wire?
FACTORY ALARM DISARM       BLACK/ WHITE (-)       IN DRIVERS KICK PANEL, HARNESS TO REAR OF VEHICLE
Chris Luongo
Platinum - Posts: 3,746
Posted: January 22, 2009 at 6:54 AM / IP Logged
The disarm wire will most likely also unlock the doors on that car.
But have you already tried without connecting it?
That car will probably just disarm all by itself upon remote start. Give it a try.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
