05 accord door lock problem
liaccord
Member - Posts: 15
Posted: January 21, 2009 at 3:46 PM / IP Logged
Fixed all the wiring for the door locks. Still in the same boat. The double pulse will unlock it well say 2 outa 4 times. this is driving me nuts.
advanced
Copper - Posts: 207
Posted: January 21, 2009 at 6:10 PM / IP Logged
Did you solder the wires? Maybe you have a bad connection somewhere. If not soldered, redo all the connections.
Have you got the 2 diodes installed to isolate lock & arm?
Good Enough Isn't!
liaccord
Member - Posts: 15
Posted: January 21, 2009 at 6:13 PM / IP Logged
yes all soldered. even used diodes on the unlock and disarm. im lost now.
advanced
Copper - Posts: 207
Posted: January 21, 2009 at 7:20 PM / IP Logged
I'll think about it & try to figure out what's wrong. Locks should work fine. I've done it that way many times.
Good Enough Isn't!
liaccord
Member - Posts: 15
Posted: January 21, 2009 at 7:54 PM / IP Logged
was chatting with a friend he suggested this. He says try and not use the red lock and green unlock and use the BLACK/ blue and BLACK/ green for arm disarm as well as to the pink/blu pink/plack. seems to think if i use one circuit it will work. What do you think?
advanced
Copper - Posts: 207
Posted: January 22, 2009 at 6:32 AM / IP Logged
You can certainly try that. You won't hurt anything.
I'll be busy today, but will try to help more tonight or tomorrow.
Good Enough Isn't!
liaccord
Member - Posts: 15
Posted: January 22, 2009 at 3:00 PM / IP Logged
well that didnt work either. I think my problem is the knob cylinder switch. reason i think that is because if i pull up the drivers lock manually then hit disarm the locks work fine. just not sure how i should wire into that.
flobee4
Silver - Posts: 585
Posted: January 22, 2009 at 3:36 PM / IP Logged
Did you try adding a relay to your unlock wire to provide a stronger ground.  Some Accords of that generation need a stronger ground pulse than your unit can provide. I myself have added a relay in here and there when a customer complains about the car intermittly unlocking.  I add the relay and all problems solved.
liaccord
Member - Posts: 15
Posted: January 22, 2009 at 3:45 PM / IP Logged
can you please just tell me how to wire up the relay? i will try this. Thanks
advanced
Copper - Posts: 207
Posted: January 22, 2009 at 6:12 PM / IP Logged
Pin 85 goes to unlock wire of remote start
Pin 86 goes to 12V+ constant
Pin 87 = Ground
Pin 30 to door unlock wire
Good Enough Isn't!
Page of 3
