12 volt power leads for remote starter
bcsman
Member - Posts: 31
Posted: February 22, 2009 at 9:51 PM / IP Logged
howie II,
Thanks for clearing that up for me!! I understand now what you were talking about. I can take the knee kick panel off below the steering column and have pretty good access to the ignition switch wiring. I can then test all the wires as they feed into the switch for 12V+ all the time. I can tell you there are a couple Light GREEN/ violet wires up there by the switch, but the "feed" wire splits off. I'll have to try and see where the split wires go but they are all in that general area. That could be what Chris was talking about when he mentioned more than one 12V+ hot wire. So I could in theory tap into a couple of the light GREEN/ violet wires but would in reality still be feeding off the same 40 amp circuit!
bcsman
Member - Posts: 31
Posted: February 24, 2009 at 7:42 AM / IP Logged
Took the kick panel off and tested all the wires on the ignition switch. There is one (1) light GREEN/ violet wire that splits off into four (4) light GREEN/ violet wires right before the switch. There is obviously 12V+ on all of those wires constantly, but that is the only color wire on the switch that has voltage all the time. Guess my wiring diagram was correct!
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
