2008 mazda 6 wiring
jpinusmc
Member - Posts: 22
Posted: February 25, 2009 at 4:55 PM / IP Logged
All,
I am looking for the wiring diagram for a 2008 Mazda 6. Can anyone help me out with this?
sonyw810
Member - Posts: 6
Posted: February 28, 2009 at 10:36 AM / IP Logged
Same as the 2007, I can not copy my data base but I compared the two and they are the same. Hope thast helps
jpinusmc
Member - Posts: 22
Posted: March 01, 2009 at 10:10 AM / IP Logged
Thank you for the help, with the lock/unlock wire, the data sheet says it is in the passenger kick near the glove box. Is there a module there I should be able to see? There are only two connectors in the kick and one ground connection higher. Is there another place to find this wire?
Also, can I use a 456lw on this wire?
Thanks again, without this site I would be totally lost.
Chris Luongo
Platinum - Posts: 3,746
Posted: March 01, 2009 at 10:50 AM / IP Logged
I did a 6 not too long ago.....I think it was a 2004 or 2005 or so, but it should be pretty much the same car.
The wires come into the driver's side of the car from the driver's door boot.
I was able to find the wire up high in the driver's kick panel, as it comes in from the driver's door. It wasn't the easiest, but I did find it there.
You might have some luck if you get under the dash with a good light, and with your free hand, reach into the car's doorjamb and wiggle the rubber wiring boot, to see if you can get the wires inside the car to wiggle around too.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
