dodge,chrysler
iteetwo
Member - Posts: 27
Posted: March 13, 2009 at 9:18 PM / IP Logged
if you take the battery out of the factory remote will the transponder inside continue to work or does it need the battery to function
JWorm
Platinum - Posts: 2,208
Posted: March 13, 2009 at 9:28 PM / IP Logged
The transponder will still work without the battery.
Mike M2
Platinum - Posts: 2,652
Posted: March 14, 2009 at 7:54 AM / IP Logged
I actually remove the board inside the remote for immobilizer programming. We use the 556CW and instead of doing it the way they describe(Deisel mode) i turn the 1st key on for 8 seconds, remove it, turn the second key in for 10 seconds, remove it, then turn the 1st key on again(without the board inside) while holding the pellet next to it. Works every time...
Mike M2
Tech Manager
CS Dealer Services
fcss
Copper - Posts: 92
Posted: March 14, 2009 at 9:16 AM / IP Logged
the battery is just for the keyless entry ,so like jworm said the transponder will still work
iteetwo
Member - Posts: 27
Posted: March 14, 2009 at 7:12 PM / IP Logged
thanx for such quick answers
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
