bypass immobilizer using relay?
bigbuffs
Member - Posts: 34
Posted: March 25, 2009 at 5:54 PM / IP Logged
I'm looking for an explanation to how this is done. When I installed the remote starter in my car there was already a very crappy one in there. My car uses the PK3 system (2000 grand prix) and they way they bypassed this was to use a relay and wrap a key in a bunch of wire. I remember seeing a diagram someone put on this site a while back but I cannot find it.
So, can anyone explain to me exactly how this works? Would it work on most cars? and does anyone have a diagram of how this is done?
Posted: March 25, 2009 at 6:24 PM / IP Logged
Chris Luongo knows the answers to this question.
dtk1
Copper - Posts: 179
Posted: March 25, 2009 at 7:47 PM / IP Logged
HERE here is a PDF file with how its wire up.you wrap the 22 gauge wire at least six time around the key and six time around the cylinder on the relay you have one to constant and the other to a GWR ground when running the way this is when you remote start the car the relay triggers and this would send the RF from the key to the cylinder now this not always work in all car only on a few I personally used these on many Chrysler and a few Honda and GM it never work for me on BMW or any euro cars
bigbuffs
Member - Posts: 34
Posted: March 25, 2009 at 8:13 PM / IP Logged
Thats what I'm lookin for. Thanks a lot I will probably be putting my old remote start into my girlfriends 99 Camry. This method should work for that car shouldn't it?
dtk1
Copper - Posts: 179
Posted: March 26, 2009 at 12:08 AM / IP Logged
yes that would work just make sure you use 22 AWG wire
JWorm
Platinum - Posts: 2,208
Posted: March 27, 2009 at 9:58 PM / IP Logged
Very few 99 Camry's had an immobilizer. I think only the v6 had one.
bigbuffs
Member - Posts: 34
Posted: March 29, 2009 at 10:19 PM / IP Logged
Well I was reading some posts and one of them said to look for the security light in the dash which are only on the XLE model which is what she has and it is V6 so I assume its got some sort of immobilizer.
KPierson
Platinum - Posts: 3,527
Posted: March 30, 2009 at 5:29 AM / IP Logged
You can buy 556U on Ebay for dirt cheap - why not go that route?
Kevin Pierson
bigbuffs
Member - Posts: 34
Posted: March 30, 2009 at 11:59 AM / IP Logged
Well I just figured since I already have the relays I wouldn't have to buy anything else but I might go that route as it looks like I can get one for $20.
blanx218
Silver - Posts: 654
Posted: April 06, 2009 at 11:05 PM / IP Logged
I would go the route of the 556u. You can also look for an Omega PASS-4. its the same as the 556u but alot less expensive.
