01 tahoe aftermarket battery problems.
devildogae
Posted: April 29, 2009 at 10:35 PM / IP Logged
I have an 01 Tahoe with Onstar but without Bose. I have a Dual xdvd710 HU and am wiring the aftermarket head unit up with a PAC OS-1 harness. I hooked it all up and it works, the sound and the HU work fine, but after a bit I noticed that my battery had been draining pretty bad. So what could it be. I have the blue power antenna wired to blue on harness, and blue/white amp remote wired to blue/white on harness.
Caleb
vibrationcustum
Copper - Posts: 171
Posted: April 30, 2009 at 5:32 PM / IP Logged
How long is a little while?
10min,30min,5hours.
How big is the battery?
Might need a bigger battery or a yellow/red top or a power cell. This might help you out
Can't be loud then don't have it.
(power acoustik system)
Head unit- TID-896 7" TOUCHSCREEN
ovn1-5500d 09 and another one coming soon
4-12" mofos 12ft3 box to 40hz (wall)
2 batterys, 1 power
icearrow6
Copper - Posts: 497
Posted: April 30, 2009 at 5:52 PM / IP Logged
"...but after a bit I noticed that my battery had been draining pretty bad"
How did you notice? Car won't start? did you measure voltages at the batt?
devildogae
Posted: May 01, 2009 at 7:45 AM / IP Logged
I noticed the battery drain about 30 min after I installed the HU that my car wouldn't start. It went from about 12 volts to about 9 volts. I have it hooked up right and I'm not pushing any large speakers. I think I have a bad battery. I charged the battery, reinstalled everything and I havn't had any problems again. Thanks!
Caleb
