wiring info for nissan quest 07
rentewarrior
Posted: May 25, 2009 at 4:01 PM / IP Logged
Can some one help me getting the wiring info for my Quest 2007? I will try to install a viper 5901 on it, any tip or comment will be appreciated
rentewarrior
rentewarrior
Posted: May 25, 2009 at 4:05 PM / IP Logged
Sorry for the rich text posting here is my question...
Can some one help me getting the wiring info for my Quest 2007? I will try to install a viper 5901 on it, any tip or comment will be appreciated.
rentewarrior
tommy...
Gold - Posts: 1,901
Posted: May 25, 2009 at 5:08 PM / IP Logged
Whats up w/ all of these 5901...Or is it just the install manual sucks...?
wiring info for nissan quest 07 - Last Post -- posted image.
BatteryGREEN(+)IGNITION SWITCH HARNESS
wiring info for nissan quest 07 - Last Post -- posted image.Ignition 1BLACK/ WHITE(+)IGNITION SWITCH HARNESS
wiring info for nissan quest 07 - Last Post -- posted image.Accessory 1RED(+)IGNITION SWITCH HARNESS
wiring info for nissan quest 07 - Last Post -- posted image.Accessory 2WHITE/ RED(+)IGNITION SWITCH HARNESS
wiring info for nissan quest 07 - Last Post -- posted image.Starter 1BLACK/ RED(+)IGNITION SWITCH HARNESS
wiring info for nissan quest 07 - Last Post -- posted image.Starter 2BLACK / YELLOW(+)IGNITION SWITCH HARNESS
wiring info for nissan quest 07 - Last Post -- posted image.Anti-Theft TypeNISSAN NVISŪ VEHICLE IMMOBILIZER
wiring info for nissan quest 07 - Last Post -- posted image.Anti-Theft DescriptTHE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
wiring info for nissan quest 07 - Last Post -- posted image.Key SenseBLACK/ RED(+)IGNITION SWITCH HARNESS
wiring info for nissan quest 07 - Last Post -- posted image.TachometerRED / BLACK(AC)AT ECM MODULE ON PASSENGER FIREWALL UNDER HOOD
wiring info for nissan quest 07 - Last Post -- posted image.Speed SensePINK/BLUE(AC)IN HARNESS AT REAR OF GAUGES
wiring info for nissan quest 07 - Last Post -- posted image.Parking LightsRED / BLUE(+)IN HARNESS IN DRIVERS KICKPANEL
wiring info for nissan quest 07 - Last Post -- posted image.Brake LightsRED / GREEN(+)AT SWITCH ABOVE BRAKE PEDAL
wiring info for nissan quest 07 - Last Post -- posted image.Reverse LightsGREEN / WHITE(+)IN HARNESS IN DRIVERS DOOR SILL
wiring info for nissan quest 07 - Last Post -- posted image.HornGREEN / WHITE(-)IN HARNESS AT STEERING COLUMN
wiring info for nissan quest 07 - Last Post -- posted image.Alarm IndicatorGREEN/ ORANGE(-)AT BCM MODULE HIGH IN DRIVER KICKPANEL
wiring info for nissan quest 07 - Last Post -- posted image.Rear DefrostWHITE/ BLUE
M.E.C.P & First-Class
Posted: May 28, 2009 at 2:06 AM / IP Logged
You tell me. We haven't seen any here because the 900mhz frequency is giving them (what remains of DEI) licensing problems, but set for manual?  Problems with the remotes? Just remember I'm (very) old school and think the AG lV was the best thing especially build quality since siced bread.  Don't forget Tommy it's an attitude problem, amateurs see us tearing into the cars and doing all these things thinking "I can do that". Back when I started apprentices weren't even allowed to touch the vehicles, they spent 6 months learning on rebuilding dynamos (YES!), aerials, window lifter mechs, learning about relays and diodes and of course the art of soldering. Ref your post on the security section, my method is to first find and test for everything you need in the vehicle, sometimes if I'm not sure, I'll even hot wire it!  Then look at the alarm r/s manufacturer's diagramme, then proceed with the usual comments about taping up, I even use fabric tape on German cars to match the original plus Scotch 33+ on solder joints, etc etc.
tommy...
Gold - Posts: 1,901
Posted: May 28, 2009 at 9:43 AM / IP Logged
Yes...Im sorry...I locate all the wires first too...Then mount brain and run wires through car...It was a long day and im sure i left a step or two out.(12 hours and 2 techs called off)..
