2002 vw golf tdi
cms customs
Member - Posts: 13
Posted: May 28, 2009 at 9:05 AM / IP Logged
i need the wiring for the remote start of the vw golf tdi 2002 model, and from where can i take the rpm
tommy...
Gold - Posts: 1,901
Posted: May 28, 2009 at 9:57 AM / IP Logged
2002 vw golf tdi - Last Post -- posted image.BatteryRED(+)IGNITION HARNESS
2002 vw golf tdi - Last Post -- posted image.Ignition 1BLACK(+)IGNITION HARNESS
2002 vw golf tdi - Last Post -- posted image.Ignition 2BLACK / YELLOW(+)IGNITION HARNESS
2002 vw golf tdi - Last Post -- posted image.Accessory 1BLACK / YELLOW(+)IGNITION HARNESS
2002 vw golf tdi - Last Post -- posted image.Starter 1RED / BLACK(+)IGNITION HARNESS
2002 vw golf tdi - Last Post -- posted image.Anti-Theft TypeRF ACTIVATED SYS.
2002 vw golf tdi - Last Post -- posted image.Anti-Theft DescriptTRANSPONDER
2002 vw golf tdi - Last Post -- posted image.Key SenseBROWN / RED(+)IGNITION HARNESS
2002 vw golf tdi - Last Post -- posted image.TachometerBLACK/ RED(AC)COIL ON FIREWALL
2002 vw golf tdi - Last Post -- posted image.Speed SenseGREEN(AC)BEHIND SPEEDOMETER PIN #28
2002 vw golf tdi - Last Post -- posted image.Parking LightsGRAY/RED GRAY(+)DRIVERS KICK PANEL *DIODE ISOLATE2002 vw golf tdi - Last Post -- posted image.
2002 vw golf tdi - Last Post -- posted image.Brake LightsRED / BLACK(+)BRAKE SWITCH
2002 vw golf tdi - Last Post -- posted image.Reverse LightsBLACK/ BLUE(+)DRIVERS KICK PANEL
2002 vw golf tdi - Last Post -- posted image.HornBLACK / YELLOW(-)BEHIND FUSES
M.E.C.P & First-Class
christophegalea
Posted: May 28, 2009 at 10:30 AM / IP Logged
i need the rpm for the vw golf 2002 tdi diesel engine
Posted: May 28, 2009 at 1:49 PM / IP Logged
It's the same!   Apart from tach.  The best by-pass to use will be the 556U if you can still  get them,  set it up as Euro-Style see the tech sheet with it, you programme your unit for diesel, no glow plug lead requred, is this an auto or manual vehicle?  Use a DEI inductive tach sensor, it's safer. If there's a factory alarm, you might have to either rip it out or get a dealer to switch it off.  In Europe assuming this is a Mk lV, you will need left and right indicators, BLACK/ green and BLACK/ white, driver's side under dash at the factory alarm or body control box. N.B. If this vehicle doesn't have power windows, you can also control the locks from that box without having to go into the driver's door. Setting your alarm to ignition lock will normally lock them. Arming the alarm will deadlock the vehicle.  If this vehicle has a tach, it might be behind the inst panel but you wil have to test, DO NOT DISCONNECT ANYTHING WHILST THE IGNITION IS ON!
cms customs
Member - Posts: 13
Posted: May 29, 2009 at 9:02 AM / IP Logged
i have programed the alarm for diesel mode, my problem is that i have installed the dei rpm monitoring module  but the alternator is not pulsing immegetly and the remote start is turning off the engine, in outo mode is working fine with virtual tech, but when i,m trying to program it for the safe way is torning off the engine, all installation is 100% good and all connections are all soldered
tommy...
Gold - Posts: 1,901
Posted: May 29, 2009 at 9:18 AM / IP Logged
Sounds like it never learned tach...Virtual tach is learned , i believe, just by starting...maybe switch to regulat tach and do tach-learn sequence again...
cms customs
Member - Posts: 13
Posted: May 29, 2009 at 9:23 AM / IP Logged
I DID THE PROGRAMING AGAIN AND AGAIN BUT WITH NO SUCSESS,I HAVE CHANGED THE ALARM MODULE AND THE RPM MONITORING MODULE BUT THE PROBLEM IS STILL THERE
THE FIRST ALARM THAT I WAS TRYING ON THE FIRST TIME NOW IS CONNECTED ON AN OTHER CAR AND IS WORKING FINE
I THINK THAT THE PROBLEM IS THE ALTERNATOR
Friday, December 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
