priority lock w/aftermarket sctuators
00sonoma
Member - Posts: 39
Posted: June 04, 2009 at 2:02 PM / IP Logged
putting a viper 791xv in my 88 stang, have the 451m module and 2 wire dei actuators in door from previous alarm.
how would go about wiring it up?
00sonoma
Member - Posts: 39
Posted: June 04, 2009 at 3:42 PM / IP Logged
sorry meant 690xv
00sonoma
Member - Posts: 39
Posted: June 06, 2009 at 7:56 PM / IP Logged
anyone?priority lock w/aftermarket sctuators - Last Post -- posted image.
00sonoma
Member - Posts: 39
Posted: June 08, 2009 at 6:11 PM / IP Logged
oh well guess it cant be done
t&t tech
Platinum - Posts: 2,622
Posted: June 08, 2009 at 6:23 PM / IP Logged
sure it can, i haven't used a 451 in a while, if i remember correctly, violet and violet/black- 12 volts permanent
brown black and WHITE/ black- ground
blue/black and GREEN/ black actuators
and the three pin harness onto the corresponding port on the 791xv brain.
00sonoma
Member - Posts: 39
Posted: June 08, 2009 at 6:42 PM / IP Logged
im trying to lock both on arm and just the driver on 1 press of unlock the pass on 2nd unlock
t&t tech
Posted: June 08, 2009 at 6:56 PM / IP Logged
ok here's what you do, remove the driver actuator unlock motor leg from the original setup,and using a relay connect like this
pin 87 and 86- twelve volts
pin 87a- ground
pin 85- connect the unlock wire of the alarm ( green)
pin 30 connect unlock leg or actuator
and on the original setup where u disconnected the unlock wire connect the second unlock in it's place
00sonoma
Member - Posts: 39
Posted: June 08, 2009 at 7:44 PM / IP Logged
awesome thanks for the info
