alarm 07 chevy silverado new body style
SoCalVWs
Member - Posts: 6
Posted: June 09, 2009 at 4:53 PM / IP Logged
Hello,
I'm still looking for an application specific alarm wiring diagram for the 2007 Chevy Silverado Crew Cab. I've seen the one for the 2007 Tahoe and the 2008 Silverado but don't want to take any chances. Does anyone have this? What about adding an amplifier to boost the stock speakers too.
Thanks,
Tim
Platinum - Posts: 12,488
Posted: June 09, 2009 at 6:28 PM / IP Logged
Alarm/Remote Start
Do you have the Bose or not ?
jim hunter
Silver - Posts: 351
Posted: June 09, 2009 at 10:30 PM / IP Logged
truck is very easy!. no data module required on any ive done yet, the lock unlock wires are
org/blk and pink/blk at bcm under dash and in plug on left side of dash under removable cover(also a dr unlock only there also(all straight negative trigger)its a lt blue
door trigger for drivers door is there also, pass door trigger in passenger side of dash (under removable cover) if has factory alarm disarm wire is only wire i havent had to search for so i am not sure if its in drivers side of dash plug or only in door
constant hot thick RED / blk at back of fusebox, ignition:pink at ignition switch
accessory:brown@ ign switch
program a blank o+ key and place in a universal transponder module(audiovox astcbm,or D.E.I. 556u)
pk lights lt blue(neg at switch)
brake wire blue/white@ switch
tach:lt blue fuel injector wire on drievers side of motor
will need a module by pac or the likes to add amp to factory system probably(im not a big stereo dealer ) but im sure someone on here or on audio forum can nail that down for you
SoCalVWs
Member - Posts: 6
Posted: June 10, 2009 at 4:01 AM / IP Logged
Velocity Motors wrote:
<A title="View 2007 GMC Sierra 4DR Pickup Car Alarm and Remote Start Wiring Information" href="https://www.the12volt.com/installbay/forum_posts.asp~TID~92759">Alarm/Remote Start</A>
No I do not.
Posted: June 10, 2009 at 8:54 AM / IP Logged
That's good, no Bose. You can use a normal LOC for this off the deck to the amplifier and then to the speakers. PAC makes some good LOC's that work well with low voltage inputs.
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
