02 ranger keyless entry/alarm
mrshoehorn
Posted: June 19, 2009 at 9:54 PM / IP Logged
I've recently purchased some auto locks and A10 alarm system for my 2dr ranger with manual locks. I've installed the actuators in both doors and wired up most of the wires.
My question has to do with finding the wires for the Green: Door Trigger Input (-) and the Purple: Door Trigger Input (+).
Any help would be awesome. Even a quick step by step for the whole thing might be informative as well.
Thanks!
~ Shoe
KarTuneMan
Platinum - Posts: 7,056
Posted: June 20, 2009 at 11:07 AM / IP Logged
t&t tech
Platinum - Posts: 2,622
Posted: June 20, 2009 at 7:04 PM / IP Logged
you will only be using the green wire of the harness, eliminate the purple, you could probably use the domelight wire, under these circumstances, if the dome light when on the door position goes out immediately when the doors are closed, or once the doors are locked the light goes out within a couple seconds, you can find this wire in either of the a pillars, in lowlux rangers it's normally in the passenger pillar. cheers
