adding sensor to oem ford alarm
flobee4
Silver - Posts: 585
Posted: July 18, 2009 at 11:18 PM / IP Logged
All the doors/hood triggers on the Explorer rest at ground when closed, so your last measurements are correct. In order to hook up an external sensor you need to "open" or "break" the wire while your sensor is tripped. I usually would use the hood Pin wire and break that wire open with a relay. So the output of your sensor needs to be hooked up to a relay. not directly to the hood pin wire.
One end of the hood wire goes to 30 of the relay, and the other goes to 87a. Wire your relay for Constant 12V(86 on relay) and Ground(85 on relay) off your sensor output. When sensor is tripped the relay will open the hood wire, this will fool the factory alarm that the hood was opened and go off.
Platinum - Posts: 13,726
Posted: July 19, 2009 at 12:46 AM / IP Logged
86 to Constant, and 85 to the negative output wire from the sensor.  I know that is exactly what you said, it just didn't really look like that.
rgcme33
Member - Posts: 23
Posted: July 19, 2009 at 10:36 AM / IP Logged
HA!!! I love it!  I thought it out this morning and tried it this way ^^^ before reading this. It works perfectly!
Page of 3
